 Quote by assaftolko
Well from conservation of momentum you get that for the first throw the momentum of the skater+skateboard after the throw minus the momentum of the first weight after the throw equals to 0.
OK.
But why is it so clear that the skater and the skateboard will move in the same velocity? They don't say anything about any friction between the skater and the skateboard and if there's no friction then when the skater throws the weight he should move to the other direction in respect to the ground and to the skateboard. The skateboard should stay put because there is no horizontal force acting upon him. Am I wrong?
Why would you think that there's no friction between skateboard and skater? You are supposed to assume that they move together, just like they normally would. (But you're correct--if the skateboard where frictionless, it would just stay put. But it would be a pretty useless skateboard!)
Also - isn't there something missing about the velocity of the second weight in order to solve the question?
Assume the same conditions apply for the second throw. Note that the velocity of the thrown weight is given
with respect to the skater.
