Finding a basis of eigenvectors
The discussion revolves around finding a basis of eigenvectors for a given 3x3 matrix. The original poster presents the characteristic polynomial and identifies the eigenvalues, followed by attempts to derive the corresponding eigenvectors.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • The original poster attempts to find eigenvectors by substituting eigenvalues into the matrix A - λI and solving the resulting equations. Some participants question the assumptions regarding the rank and nullity of the matrices involved, while others explore the implications of the dimensions of the solution space.
Participants are actively engaging with the concepts of rank, nullity, and the relationship between them in the context of eigenvectors. There is a recognition of the need for multiple eigenvectors corresponding to the repeated eigenvalue, and some guidance is provided regarding the dimensions of the solution space.
There is a discussion about the implications of the rank of the matrix and the potential for differing algebraic and geometric multiplicities, which may affect the number of independent eigenvectors available.
Catchfire
[itex] A = \left( \begin{array}{ccc}<br /> 2 & 0 & -1 \\<br /> 4 & 1 & -4 \\<br /> 2 & 0 & -1 \end{array} \right)[/itex]
Find the eigenvalues and corresponding eigenvectors that form a basis over R3
OK so I've found the characteristic polynomial: -λ(λ-1)2
so I know my eigenvalues are 0,1,1
Then to find the eigenvectors I sub the eigenvalues into the matrix A - λI
[itex] A - 0I = \left( \begin{array}{ccc}<br /> 2 & 0 & -1 \\<br /> 4 & 1 & -4 \\<br /> 2 & 0 & -1 \end{array} \right)[/itex]
then I solve:
2x -z = 0
4x + y -4z = 0
z = 2x
y = 4x
so my eigenvector is (1,4,2)
[itex] A - 1I = \left( \begin{array}{ccc}<br /> 1 & 0 & -1 \\<br /> 4 & 0 & -4 \\<br /> 2 & 0 & -2 \end{array} \right)[/itex]
x = z
so the eigenvector is (1,0,1)
Now I'm out of new eigenvalues to substitute. How do I find the last eigenvector?
The rank of the second matrix is 1, so there are two independent eigenvectors to get from it.
So are you saying dim(A) = rank(A) + nullity(A)
and since dim(A-I) = 3 and rank(A-I) = 1, then nullity(A-I) = 2, implying I need two vectors from A-I.Ahh I see where I messed up, since there is no y values I can write y = a for any a in R.
So really my eigenvectors are (1,a,1) and (0,b,0).
Is all of this correct?
What is preventing you from substituting these vectors into the equation to check if they work?
RGV
Nothing, but I already know the answers to the problem. I just wanted to make sure my reasoning was correct and that I understood what theorem voko was citing.
Can you lend a hand with any of that? It would much appreciated if you could.
I do not remember whether that theorem has any particular name, but it states that the dimension of the solution space of a homogeneous linear system is the dimension of the system minus its rank. And you got that correctly.
But YOU yourself already cited the result in your post!
In the present case the 3x3 matrix is so simple that one can spot immediately that it has rank 1. In more complex cases (say a 5x5 or a 10x10 matrix), finding the rank involves essentially the same algorithm that one uses to solve the system Ax=0 (Gaussian elimination/row-reduction), so you determine the dimension of the null space (and find a basis for it) at the same time that you find the rank.
RGV
Well, in the case of eigenvectors one knows the rank even before that.
No. The algebraic and geometric miltiplicities may differ, in which case the dimension of the null space can be less than the multiplicity. That is why the Jordan form is sometimes non-diagonal.
RGV
Thanks for the responses, I appreciate the help.
