| New Reply |
I have a question on gravity |
Share Thread | Thread Tools |
| Aug8-12, 07:36 PM | #1 |
Could a planet hold a significant atmopshere of Co2 O2 N and H2O if the gravity was 50% Earths if under the right conditions?
| Aug8-12, 07:48 PM | #2 |
Sure, under the right conditions. Only particles that reach escape velocity will leave the atmosphere, and for that to happen, you need heat. The escape velocity on a planet with weaker gravity will be smaller, but if the temperature of the planet is lower, the particles will be slower. Even if the gravity is weaker, there might still be a smaller portion of gas particles that are able to escape the atmosphere.
One thing to consider though is that with a much lower temperature, you may not see the same chemical processes which form those compounds here on earth. |
| Aug8-12, 08:10 PM | #3 |
So if a planet with this gravity was inbetween earths and mars distance do you think it could hold onto the atmosphere? Id imaine if it were at venuses distance there would be no atmoshpere.
| Aug8-12, 08:33 PM | #4 |
| Aug8-12, 08:51 PM | #5 |
Ok so i made up a hypothetical exoplanet that has a mass of .205 earths with a density of 5.20 g/cm3 and a radius of .60 earths and gravity is 57% earths with an orbit of 402 days around a sun like star. The temperature for the planet is around 275 K Could a planet like this retain a thick enough atmosphere for life? Any possibility for life?
| Aug8-12, 10:23 PM | #6 |
[itex]\Large v_{e}=\sqrt{\frac{2GM}{r}}[/itex] For your planet, it would be about 6.5 km/s, while earth's escape velocity is about 11.2 km/s. Using the Maxwell-Boltzmann distribution for the speed of gas particles, you could determine the relative amount of gas you'd expect to lose compared to earth. However, just by taking a look at a plot of the Maxwell-Boltzmann distributions for a few gases at 298°K, you can see that even the lighter gases seem to fit well within the range of your escape velocity. Without actually going into the math for the Maxwell-Boltzmann probability density, this seems to indicate that a planet of those proportions would be able to sustain an atmosphere similar to earth's. The temperature could even be a bit higher. |
| Aug8-12, 10:43 PM | #7 |
So a planet like this could be habitable. Wow and some people tell me that a planet like that cant have life because of its size haha.
| Aug9-12, 04:33 PM | #8 |
What about 290 K or would that be too hot for this planet?
| Aug9-12, 04:40 PM | #9 |
I think it would be fine. The Maxwell-Boltzmann distribution I posted is for 298°K.
| Aug9-12, 05:17 PM | #10 |
Recognitions:
(I did some digging and got some numbers. For the hypothetical planet in question, you could probably hold onto any substance with a weight over 6amu for 10Gyr+. Which is basically everything not H and He.) Apparently though, there are other processes at work which can strip a planet of its atmosphere. Things like stellar wind and ionizing radiation come to mind, but I'm not familiar enough with how these work to state numbers. |
| Aug9-12, 10:55 PM | #11 |
The planet would have a global magnetic field.
| Aug10-12, 03:54 AM | #12 |
Recognitions:
Temperatures in Thermosphere can reach 1,800 K. That's going to throw all of the above computations way off.
For a hypothetical planet, the Thermosphere temperature will depend on parent star's UV output. So a planet orbiting a blue star will have harder time holding on to its atmosphere than one orbiting a red star, provided equal energy flows from both. And, of course, magnetic field is vital for holding on to the atmosphere. Just look at Mars. |
| Aug10-12, 04:33 AM | #13 |
What about a yellow or orange star? Yea i feel bad for mars like if it kept its field we might actually see small patches of liquid water givin the air pressure was enough.
| Aug10-12, 09:21 AM | #14 |
Mentor
We had a similar discussion some days ago in the astronomy forum here, with the same thread starter. |
| Aug11-12, 06:57 PM | #15 |
I understand atmospheric stripping in the thermosphere because of the much higher temperatures spacing between particals. But doesnt the maxwell boltzmann thing explain gases closer to the ground? Cause that would make sense earths temp is 288k and as stated above the chart describes gases at 298 k and the higher up you go the lower the temp is untill you et to the mesosphere and thermosphere.
| Aug12-12, 05:48 AM | #16 |
Mentor
The Maxwell-Bolzmann-distribution is valid for all gases in equilibrium - to a good approximation, this is true for all gases everywhere in the atmosphere. The temperature is not the same everywhere, therefore the distribution depends on the height.
| Aug12-12, 02:13 PM | #17 |
makes sense.
| New Reply |
| Tags |
| atmosphere, gravity, heat., mass, planet |
| Thread Tools | |
Similar Threads for: I have a question on gravity
| Does gravity affect gravity the way gravity affects time? | General Physics | 12 | ||
| A question on Gravity Waves and Gravity Radiation | Cosmology | 3 | ||
| Gravity/Planetary Forces Question - High School physics question | Introductory Physics Homework | 5 | ||
| A question on gravity | General Physics | 2 | ||
| gravity question | General Astronomy | 3 | ||
