New Reply
Angle Modulation
Share Thread Thread Tools
Aug10-12, 03:33 AM   #1
Angle Modulation
Q1. A device with input x(t) and output y(t) is characterized by y(t) = x(t). If a FM signal with frequency deviation 90 Khz and modulating frequency 5 Khz is applied to the input terminals of the device then what will be the bandwidth of the output signal received ?
What i did was calculated the modulating index i.e by dividing frequency deviation by the modulating frequency and got the value equal to 18. Then by using carson rule calculated the bandwidth of the FM signal to be B.W = 2(18 + 1)(5) = 190 Khz.
But answer is not this , how should i do the question then ?
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> 'Whodunnit' of Irish potato famine solved
>> The mammoth's lament: Study shows how cosmic impact sparked devastating climate change
>> Curiosity Mars rover drills second rock target
Aug10-12, 04:21 AM   #2
Decades since I did this but isn't the modulation index the other way up eg
5/90 = very low
so only one pair of side bands?
B.W = 2(v.small + 1)(5) = 10 Khz
Aug10-12, 04:22 AM   #3
Recognitions:
Gold Membership Gold Member
I got the same answer you did: 2(90 + 5) the way I did it.
Maybe your source wasn't satisfied with 98% of the energy contained within the Carson bandwidth. After all, the real answer is infinity! The Bessel function expansion of the modulated carrier extends without limit ...
Aug10-12, 04:36 AM   #4
Angle Modulation
The answer given to me was 380 Khz that is 2 * 190 and i dnt know why , do it have to do something with the transfer function but h(t) = 1 since y(t)=x(t) , the FM signal is having bandwidth equal to 190 Khz at the time of input but how and why will it double when passed through the device having relationship y(t) = x(t), please help ?
Aug10-12, 04:37 AM   #5
Quote by rude man View Post
why is the real answer infinity ?
Aug10-12, 04:38 AM   #6
Quote by CWatters View Post
5/90 = very low
Modulation index is 90/5 , i gave frequency deviation to be 90 and modulating frequency to be 5
Aug10-12, 04:57 AM   #7
Recognitions:
Quote by lazyaditya View Post
Because if you expand the modulated signal in a series, that series has an infinite number of harmonics. In this case it's a Bessel series. You get Bessel series whenever you get functions like sin(a + bsin(x)) etc. This should be available somewhere in Wikipedia, if your textbook doesn't cover the subject rigorously.
E.g. http://en.wikipedia.org/wiki/Frequency_modulation
Aug10-12, 05:19 AM   #8
Deleted
Aug10-12, 05:42 AM   #9
Ya total bandwidth is infinity but we don't consider the low powered components right? so they are neglected. But what about 380 Khz ?
Aug10-12, 08:00 AM   #10
Recognitions:
Homework Helper Homework Help
With a modulation index of 18 it would be considered broadband FM, I think. But I can't see how bandwidth can be much different from 2*(18+1)*5 kHz.
Aug10-12, 03:35 PM   #11
Recognitions:
Right on the first part.
As for the second: I have no idea where the 380KHz comes from. It's obviously twice the answer we're getting. Are you sure you wrote the question down right? Seems funny they gave you y(t) = x(t). That's just a straight feedtru from input to output! If they had given you y(t) = x2(t) then you would have generated the 2nd harmonic of 190 KHz = 380 KHz at the output.
Aug10-12, 08:54 PM   #12
Recognitions:
Ding! I believe we have the winner.
Aug11-12, 01:57 AM   #13
Thanks for this , i think then the question in book would have been wrong and answer would have been this "380 Khz" when y(t)= x^2(t)
New Reply
Thread Tools
Similar Threads for: Angle Modulation
Thread Forum Replies
angle of incidence, angle of refraction and angle of reflection Introductory Physics Homework 1
modulation again Electrical Engineering 2
AM modulation. Electrical Engineering 13
AM/FM modulation Introductory Physics Homework 1
Modulation Electrical Engineering 2
