Trying to understand the normalisation of the scale factor to be 1 today
The discussion revolves around the normalization of the scale factor in cosmology, specifically addressing how to set the scale factor to 1 at the present time (t_0). Participants explore the implications of different normalization methods on the relationship between density and time in an expanding universe, referencing the Friedmann equations and power law expansions.
  • One participant presents the Friedmann equation for a spatially flat Robertson Walker metric and discusses the implications of normalizing the scale factor such that a(t_0) = 1, questioning how this affects the density relation over time.
  • Another participant challenges the interpretation of the density relation, asserting that density decreases as time increases, regardless of whether t is greater than or less than 1.
  • A later reply introduces two methods for normalizing the scale factor: changing units to set t_0 = 1 or using a dimensionless scale factor defined as a(t) = (t/t_0)^{2/3}.
  • One participant argues that the scale factor should be dimensionless and suggests that the second normalization method is preferable, while questioning the validity of the first method.
  • Another participant clarifies that the convention is to define the scale factor as a ratio of proper distances, emphasizing that it is arbitrary what time is defined as t_0, though it is typically taken as the present time.
  • Concerns are raised about the implications of setting t_0 = 1, particularly regarding the units of time and the potential for misinterpretation in calculations.
  • One participant suggests a straightforward approach to normalization by expressing all past times in terms of t_0, aligning with the second proposed equation.
Participants express differing views on the appropriate method for normalizing the scale factor, with no consensus reached on which approach is correct. There is also disagreement regarding the implications of normalization on the density relation over time.
Participants highlight the importance of dimensional consistency in the normalization process and the potential confusion arising from different interpretations of time units. The discussion remains open regarding the best practices for normalization and the calculation of t_0.
Heldo Jelbar
Hello all! I'm trying to understand the standard normalisation of the scale factor to be set to 1 at today's time. Looking at the first Friedmann Equation for a spatially flat Robertson Walker metric with no cosmological constant gives
[tex]\frac{\dot{a}^2}{a^2} = \frac{8\pi G}{3}\rho[/tex]
If we wanted to see how the density of the universe changed from the beginning of the matter dominated era to today, we would set
[tex]a(t) = t^{2/3}[/tex]
This means that,
[tex]\frac{\dot{a}^2}{a^2} = \frac{4}{9t^2}[/tex]
inserting this back into the Friedmann Equation, we get
[tex]\rho = \frac{1}{6\pi Gt^2}[/tex]
So we see that in a expanding universe the density decreases as [itex]1/t^2[/itex], which is sensible. But my question is this: if we normalise the scale factor [itex]a(t)[/itex] such that [itex]a(t_0) = 1[/itex], where [itex]t_0[/itex] is today's time, then one way of doing this is to use units where [itex]t_0 = 1[/itex]. This then would make [itex]a(t_0) = 1[/itex] straightforwardly for any power law expansion of scale factor. But normalising the scale factor in this way messes with the density time relation. As all times in the past have [itex]t< 1[/itex], a [itex]1/t^2[/itex] relation will actually show that the density is INCREASING in time as the universe expands, as [itex]t[/itex] is less than one before today. But this is no longer sensible.
So does anyone know how to correctly normalise the scale factor to avoid this issue? Any answers with their justifications would be great, and a reference to where I can read more about this would be even better! Many many thanks in advance!
Space news on Phys.org
What are you talking about? If the density ~ 1/t^2, the density will always be decreasing as t increases, regardless of whether t>1 or t<1.
Sorry, you're right. There was a deeper reason I was asking however. There seem to be two different ways in which the scale factor can be normalised, at least as far as I can see. Either you can:
1) Change your units of time such that [itex]t_0 = 1[/itex], and use [itex]a(t) = t^{2/3}[/itex]
2) Normalise the scale factor by setting [itex]a(t) = \left(\frac{t}{t_0}\right)^{2/3}[/itex]
I'm not sure which is the correct one. In the first case simply changing the units means that the scale factor has dimensions, time to the power 2/3. In the second case the scale factor is dimensionless. I think the correct answer is the second one, and I was trying to think of why the option 1) wouldn't be allowed, which made me make the mistake you pointed out. I think that the scale factor has to be dimensionless.
Does anyone know how exactly the scale factor is normalised? Is the normalisation factor as simple as in option 2), or are there more terms? Do you know where I can find out more? For instance, how is the value of [itex]t_0[/itex] calculated?
Well, I'm not saying this is the only way to do it, but I think the convention is that the scale factor is defined to be a ratio between the proper distance at time t and the proper distance at time t0. As such it is dimensionless, and the scale factor at time t0 = 1.0. It is then arbitrary what time is defined as t0, but it is usually taken as t0 = today.
Well, setting [itex]a(t_0) = 1[/itex] is a trivial operation, because the scale factor has no units. However, setting [itex]t_0 = 1[/itex] is not a trivial operation, because [itex]t_0[/itex] has units. If you are using kilograms-meters-seconds units, for instance, performing the manipulations as you have above essentially ends up setting [itex]t_0 = 1s[/itex], not [itex]t_0=1[/itex]. And arbitrarily setting the current age of the universe to one second is obviously wrong.
One simple way to take care of this would be to just put every time in the past in terms of [itex]t_0[/itex]. This would be equivalent to Heldo Jelbar's second equation:
[tex]a(t) = \left({t \over t_0}\right)^{2 \over 3}[/tex]
  • · Replies 93 ·
14K
