Error in Young/Freedman 13th? (Integral)
  • Thread starter Thread starter SiennaTheGr8
    Error Integral
In the discussion about Young/Freedman's University Physics, 13th edition, a discrepancy arises between the integration of Eq. 5.10 and the provided Eq. 5.12. The user initially believes there is an error in the text due to an additional term in the book's equation that they cannot account for. After further analysis, it is clarified that the difference stems from the integration being treated as indefinite rather than definite, leading to an additive constant. The user ultimately realizes that recognizing this constant resolves the confusion regarding the initial conditions of the equations. This highlights the importance of understanding the context of integrals in physics equations.
SiennaTheGr8
In chapter 5 of Young/Freedman's University Physics, 13th ed., Eq. 5.10 is given as:
##v_{y} = v_{t}(1 - e^{-\frac{k}{m}t})##,
where v_{y} is the time-dependent speed in the vertical direction of a low-mass, slow-moving object falling through a fluid, and ##v_{t}##, ##k##, and ##m## are all constants (terminal speed, proportionality constant, and mass, respectively).
Eq. 5.12 is supposed to be the time integral of Eq. 5.10, and is given as:
##y = v_{t}\Big(t - \frac{m}{k}(1 - e^{-\frac{k}{m}t})\Big)##,
where ##y## is the time-dependent position of the object in the vertical direction.
The authors do not provide the derivation. When trying to integrate Eq. 5.10 myself, however, I came up with:
##y = v_{t}\Big(t + \frac{m}{k}(e^{-\frac{k}{m}t})\Big)##.Here are my steps:
Distribute ##v_{t}## on the right side of the equation:
##v_{y} = v_{t} - v_{t}e^{-\frac{k}{m}t}##
Integrate term-by-term, treating ##v_{t}## as a multiplicative constant:
##y = v_{t}∫dt - v_{t}∫e^{-\frac{k}{m}t}dt##
##y = v_{t}t - v_{t}∫e^{-\frac{k}{m}t}dt##
Using u-substitution for the last term, treating ##\frac{k}{m}## as a constant ##c##:
##∫e^{-ct}dt##,
where
##u = -ct##
##\frac{du}{dt} = -c##
##dt = \frac{du}{-c}##,
we have:
##\frac{1}{-c}∫e^{u}du##
##\frac{1}{-c}e^{u}##
##\frac{1}{-c}e^{-ct}##.
Subbing back in for ##\frac{k}{m}##:
##-\frac{m}{k}e^{-\frac{k}{m}t}##.Now the right-hand term of the equation becomes:
##(-v_{t})(-\frac{m}{k})e^{-\frac{k}{m}t}##,
and the whole equation:
##y = v_{t}t + v_{t}(\frac{m}{k})e^{-\frac{k}{m}t}##
##y = v_{t}\Big(t + \frac{m}{k}(e^{-\frac{k}{m}t})\Big)##.But again, the book gives
as the answer. Distributing the ##-\frac{m}{k}## in their answer gives:
##y = v_{t}\Big(t - \frac{m}{k} + \frac{m}{k}(e^{-\frac{k}{m}t})\Big)##,
which is the same as my answer, except with an additional term of ##-\frac{m}{k}## in the big parentheses.
I'm not a very competent mathematician, and I've probably made an error somewhere, but I can't spot it, and I don't see where their extra term of ##-\frac{m}{k}## comes from. Am I integrating improperly? Or is this actually an error in the text?
Thanks, and sorry for the lack of LaTeX.
[Edited: basic LaTeX added]
Mathematics news on Phys.org
vy = vt[1 - e-(k/m)t],
where vy is the time-dependent speed in the vertical direction of a low-mass, slow-moving object falling through a fluid, and vt, k, and m are all constants (terminal speed, proportionality constant, and mass, respectively).
y = vt[t - (m/k)(1 - e-(k/m)t)],
where y is the time-dependent position of the object in the vertical direction.
y = vt[t + (m/k)(e-(k/m)t)].
Here are my steps:
Distribute the constant vt on the right side of the equation:
vy = vt - vte-(k/m)t
Integrate term-by-term, treating vt as a multiplicative constant:
y = vt∫dt - vt∫e-(k/m)tdt
y = vtt - vt∫e-(k/m)tdt
Using u-substitution for the last term, treating (k/m) as a constant c:
∫e-ctdt,
where
u = -ct
du/dt = -c
dt = du/-c,
we have:
(1/-c)∫eudu
(1/-c)eu
(1/-c)e-ct.
Subbing back in for k/m:
(-m/k)e-(k/m)t.
((-vt)(-m/k))e-(k/m)t,
y = vtt + (vtm/k)e-(k/m)t
as the answer. Distributing the -(m/k) in their answer gives:
y = vt[t - m/k + (m/k)(e-(k/m)t)],
which is the same as my answer, except with an additional term of -(m/k) in the brackets.
I'm not a very competent mathematician, and I've probably made an error somewhere, but I can't spot it, and I don't see where their extra term of -(m/k) comes from. Am I integrating improperly? Or is this actually an error in the text?
Don't apologize for the lack of Latex. Better learn how to use it in this forum and thus make yourself a good
service as the way it is your message has less chance to be read and addressed by other people than it'd have
if you'd write it with Latex.
DonAntonio
DonAntonio
Thanks -- added some basic Latex.
If the expression \,v_t\, is really a constant wrt \,t\, (and this is odd for me because it
has a subindex depending on t), then you're right and the book's wrong.
Nevertheless I'd try to be dead sure about that \,v_t\, since it is not usual so huge mistakes in known textbooks.
DonAntonio
Differentiating 5.12, we get 5.10. No problem there.
What you miss is that any indefinite integral is defined up to an additive constant. Which is what is different between your solution and the book's. Why the constant in the book has that particular form, should be evident from other conditions on the function sought.
Yes, the additive constant crossed my mind, but I think in this case it should be zero, since the initial position seems to be the origin on the given y-t graph that we are told represents Eq. 5.12. I very well might be missing something, but I read nothing in the text that would indicate that the term ##-\frac{m}{k}v_t## should be the initial condition.
(Eq. 5.12 is only given in passing to show mathematically what is happening in that particular figure. The equation is never brought up again, as far as I can tell, so I figured it's the kind of error that might easily go undetected, if it's an error at all.)
I'd also add that the terminal speed ##v_t## of a low-mass, slow-moving object falling through a fluid is defined in the text as ##v_t = \frac{mg}{k}##, and so if this mysterious ##-\frac{m}{k}v_t## term is really the additive constant, then wouldn't that imply that the initial y-position is ##-\frac{m^2}{k^2}g##? I just don't understand how a term like that could have anything to do with the initial position of a small object slowly falling through a fluid.
(In the given frame of reference, by the way, the negative y-direction is up, and the positive y-direction is down).
Sorry if I'm just being dense.
Still, the mystery term does yield the correct unit (meters), since the constant of proportionality ##k## has units kg/s. I still have no idea where the term comes from, and its existence seems to contradict the given y-t graph, which clearly shows the origin as the initial condition.
Ah, figured it out.
Classic rookie mistake: it was a definite integral from time 0 to t, not an indefinite integral. Substituting 0 for t in my indefinite integral equation indeed yields the mystery term.
Thanks for the help!
