New Reply
Charge in conductors
Share Thread Thread Tools
Aug13-12, 07:01 AM   #1
A sphere conductor of radius 18 cm has potential 27 Volt. Another sphere conductor has potential 18 Volt. Both of them are connected and the combined potential is 24 Volt. Find:
a. the charge of second sphere
b. the charge of each sphere now
2. Relevant equations
Q = CV
V = kQ / r
3. The attempt at a solution
a.
V1 = k.Q1 / r1
27 = 9 x 109 x Q1 / (18 x 10-2)
Q1 = 5.4 x 10-10 C
Then I don't know how to continue.....
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Front-row seats to climate change
>> Attacking MRSA with metals from antibacterial clays
>> New formula invented for microscope viewing, substitutes for federally controlled drug
Aug13-12, 07:09 AM   #2
Try using conservation of charge.
EDIT: Are those two sphere of same radius?
Aug13-12, 07:52 AM   #3
Homework Helper 2012
Recognitions:
Homework Helper Homework Help
You can calculate also the final charge Q1' on the first sphere, as its potential is known.
As for the second sphere, kQ2/R2=18 and kQ'2/R2=24. From here, you can find the ratio Q2'/Q2. As AGNuke said, the sum of the charge on the spheres is conserved: Q1+Q2=Q1'+Q2'.
ehild
Aug13-12, 11:22 PM   #4
Quote by AGNuke View Post
I don't know but maybe they are not
Quote by ehild View Post
ehild
V' = k Q1' / r1
24 = 9 x 109 x Q1' / (18 x 10-2)
Q1' = 4.8 x 10-10 C
kQ2/R2=18 ; kQ'2/R2=24
So Q2'/Q2 = 24/18 = 4/3
Q1+Q2=Q1'+Q2'
5.4 x 10-10 + Q2 = 4.8 x 10-10 + 4/3 Q2
Q2 = 1.8 x 10-10 C
Q2' = 2.4 x 10-10 C
If the spheres have same radius, then the combined potential should be: (27 + 18)/2 = 45/2 V. Am I correct in this case?
Thanks
Aug13-12, 11:37 PM   #5
Recognitions:
Quote by songoku View Post
Q2 = 1.8 x 10-10 C
Q2' = 2.4 x 10-10 C
Thanks
Your solution is excellent and you are right, if the radii were the same the final voltage would be 22.5 V.
ehild
Aug14-12, 04:26 AM   #6
OK. Thanks a lot
New Reply
Thread Tools
Similar Threads for: Charge in conductors
Thread Forum Replies
Charge Distribution on Two Neighboring Conductors Classical Physics 2
Determining total charge on the surfaces of spherical conductors Introductory Physics Homework 3
To find charge and capactitance of a finite conductors Engineering, Comp Sci, & Technology Homework 0
Difference between charge, specific charge, relative charge and elimentary charge? High Energy, Nuclear, Particle Physics 1
help needed: Charge on 2 spherical conductors connected with a cylindrical conducor Advanced Physics Homework 4
