New Reply
Lagrangian question
Share Thread Thread Tools
Aug13-12, 05:45 PM   #1
Lagrangian question
Right I've got a relativistic particle in D dimensional space interacting with a central potential field. Writing out the entire lagrangian is a bit complicated on this but I'm sure you all know the L for a free relativistic particle. The potential term is Ae-br where r is the position vector.
(i) Find the momentum p as a function of the velocity v.
(ii) Find Lagrange's equations of motion for the particle.
(iii) Find the velocity v as a function of P and r.
2. Relevant equations
3. The attempt at a solution
(i) That would be mvi/root(1 - v2/c2)
(ii) ∂L/∂xi = d/dt(∂L/∂vi) , Pi = ∂L/∂vi
So dPi/dt = Abe-brxi/r
(iii) This is the part I'm having a problem with.
I have that v2 = P2c2/(m2c2 + P2) But I have no idea how to get r into the equation.
Advice please?
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Galaxies fed by funnels of fuel
>> The better to see you with: Scientists build record-setting metamaterial flat lens
>> Google eyes emerging markets networks
Aug14-12, 01:37 PM   #2
Recognitions:
Homework Helper Homework Help
Hi Maybe_Memorie!
Did you know that f(x,y)=g(x) for any y, is not only a function of x and y, but also a function of x?
Yeah... I know, it sounds a bit lame, but it's true nonetheless.
Aug14-12, 03:47 PM   #3
Hey I Like Serena!
So are you saying that since I need to find V(r,p), my answer as a function of p is also a function of r for all r?
Aug14-12, 03:51 PM   #4
Recognitions:
Lagrangian question
Yes. I believe that you have v(r,p)=v(p).
It's fairly typical that p and v are independent of position in potential fields.
Aug14-12, 04:18 PM   #5
So my answer is correct then?
Also I have another question.
How do the coordinates xi and momenta Pi transform under an infinitesimal rotation in the x2x4-plane?
Well, under this transformation, I know that xi, i not equal to 2 or 4 will just go to xi. In other words, invariant.
If i = 2,4, then xi -> xi + εijxj where εij is an infinitesimal parametrisation of the rotation.
Same for Pi. Is this correct?
Aug14-12, 04:23 PM   #6
Recognitions:
Quote by Maybe_Memorie View Post
I believe so.
Do you have a reasoning to support that?
Aug14-12, 04:38 PM   #7
Quote by I like Serena View Post
Well for my first statement I'm just imagining a three dimensional coordinate system. It's clear to see that then when you rotate the x-y plane the z axis will remain unchanged.
But if I need to be more rigorous, if I take my other statement of xi -> xi + εijxj which I know to be true since it was proved in class, we will have in this case xi -> xi + εjkxk and the second term just wouldn't make sense, so it would be zero.
So I guess in general xi -> xi + δijεjkxk where δij is the kronecker delta.
Aug15-12, 11:09 AM   #8
Seems like a very badly worded question
eg. presumably r is the length of the position vector.
Bearing in mind the spherical symmetry of the problem, it would make more sense if they asked for say the speed of the particle as a function of r.
I would use the matrix
[tex]\epsilon_{1i3j567...}[/tex]
to generate this rotation, where ε is the completely antisymmetric symbol. Note that the i and the j go in places 2 and 4.
Aug17-12, 05:58 PM   #9
Recognitions:
Okay, well... did you figure it out?
Aug17-12, 06:40 PM   #10
I'm not sure if my argument 3 posts up is correct or not. It makes sense to me, but I'm not sure if it's right.
Any kind of point in the right direction?
Aug17-12, 10:08 PM   #11
I think that wouldn't make sense simply because the indices don't match up.
When you sum over j, you're back to where you started, no?
But I can heartily recommend the matrix I suggested 3 posts back
Aug18-12, 03:33 AM   #12
Recognitions:
x and P are vectors.
Vectors themselves are independent of coordinate system.
It's only their representation into coordinates that depends on a coordinate system.
If you have a formula to represent the vector x in coordinates xi, or rather a formula to transform its coordinates to another coordinate system (as you do), then that exact same formula applies to represent the vector P in coordinates of the same coordinate system.
So yes, you are correct.
New Reply
Thread Tools
Similar Threads for: Lagrangian question
Thread Forum Replies
some lagrangian question Classical Physics 3
looking for Lagrangian Systems with Higher Order Time Derivatives in the Lagrangian Special & General Relativity 1
Lagrangian Question Introductory Physics Homework 3
Question about Lagrangian Quantum Physics 5
lagrangian question Advanced Physics Homework 1
