| New Reply |
Find the Total Current in a Single Loop Circuit |
Share Thread |
| Aug18-12, 07:10 PM | #1 |
Find the current flowing through the circuit. ![]() 2. Relevant equations Amps=Total Voltage / Total Resistance 3. The attempt at a solution (20 + 12 + 12 + 3) / (10 + 5 + 30 + 40 + 20 + 15)=0.39A I'm almost certain that this is wrong. I don't even know if the formula I used is actually valid. Any help you can provide would be greatly appreciated. On an unrelated note, has anyone seen a good explanation of the right-hand rule (for magnetic fields)? ***Sometimes, the image might not display. I don't know why. If that happens, right click the little icon that shows in its place and copy the image URL. |
| Aug18-12, 11:43 PM | #2 |
Recognitions:
Your Relevant Equation is okay, but beware that the polarity of the individual voltage sources matter; look closely at each of the battery symbols as you 'go around' the loop.
| Aug19-12, 02:16 AM | #3 |
if you go around the loop carefully, i think the answer is (-20+12+12-3)/(5+30+40+20+15+10)=0.00833A
| New Reply |
Similar discussions for: Find the Total Current in a Single Loop Circuit
| hand rule used to find the magnetic field in a single loop wire | General Physics | 1 | ||
| Stuck on a single loop circuit, two emfs and resistor... | Introductory Physics Homework | 4 | ||
| Cartesian equation for the Magnetic field resulting from a single current loop? | Classical Physics | 3 | ||
| Solving a Simple Circuit involving Current Source by the Loop Current Method.. | Introductory Physics Homework | 2 | ||
| Single Loop Circuit Energy Conservation | General Physics | 2 | ||
