Finding the volume of an ellipsoid by using the volume of a sphere
The discussion revolves around finding the volume of an ellipsoid defined by the equation (x/a)² + (y/b)² + (z/c)² = 1, utilizing the known volume of a unit sphere in R³, which is 4π/3. Participants are exploring the relationship between the ellipsoid and the unit ball, particularly through variable substitutions and transformations.
  • Participants discuss using spherical coordinates and substitutions like u = x/a, v = y/b, and w = z/c to relate the ellipsoid to the unit ball. There are considerations about how the limits of integration might change and the implications of the Jacobian in the transformation process.
Some participants have suggested focusing on the Jacobian and its role in the transformation from Cartesian to the new coordinate system. There is acknowledgment of the diagonal nature of the Jacobian matrix and its implications for the volume calculation. However, there remains some uncertainty about the notation and the specifics of the Jacobian's application.
Participants express confusion regarding the Jacobian in Cartesian coordinates and its relationship to the transformation being discussed. There is also mention of the need for clarity in notation and matrix representation within the context of the discussion.
Fractal20
So I keep coming across problems that suggest finding the Volume of an ellipsoid using the volume of a ball ie:
Find the volume enclosed by the ellipsoid:
(x/a)^2 + (y/b)^2 + (z/c)^2 = 1
by using the fact that the volume of the unit ball in R^3 is 4pi/3
I keep getting stuck on this one. It seems like it will be some change of variables in which abc will eventually just pop out front of the usual expression for the volume of a ball. I keep thinking that I should be able to use spherical coords and a substitution like u = x/a, v = y/b and w = z/c. But then you just get the normal unit ball integral. I feel like it might come out of the limits of the integral in terms of P. That is, the maximum length of p is a function of [itex]\phi[/itex] and [itex]\theta[/itex] in the ellipsoid case. But with the above substitution then P is 1. Or I keep thinking it might come out of dP, but that hasn't been clear either.
I also keep thinking of plugging in for p -> p = [itex]\sqrt{u<sup>2</sup> + v<sup>2</sup> + w<sup>2</sup>}[/itex] = [itex]\sqrt{(psin \phi cos \theta)<sup>2</sup>/a + (psin \phi sin \theta)<sup>2</sup>/b + (pcos \phi cos \theta)<sup>2</sup>/c}[/itex] but then the p2 term would cancel out.
Anyway, I am just going in circles. Does anybody have any suggestions?
The volume of the ellipsoid is$$
\iiint_V 1dxdydz$$in the ##xyz## plane. Don't think in terms of spherical coordinates, think more about what the ellipsoid becomes in ##uvw## space under the transformation you are thinking about which I have highlighted. And the Jacobian has something to do with it.
Is it simply that x/a = u -> dx = adu and etc?
I think I can see it from the Jacobian in Spherical but not Cartesian. Like if u,v,w are defined like normal in spherical coordinates, then making the jacobian makes a factor of a across the first row, b on the second and c on the third which pull out in the determinant.
But the Jacobian in cartesian still seems weird. So:
∫∫∫R(xyz)dV = ∫∫∫R(uvw) J dV
But in cartesian x=ua, y=vb and z=wc only defines the "functions" in terms of one other variable (x = f(u), y=g(v) etc...) then fv(u) is 0 etc. I am pretty new to Jacobians so I am problem just have a misunderstanding with them.
Ohhh! I see the Jacobian will just be a diagonal matrix, so it won't be 0. Thanks, sorry I can be a little slow.
So do you see how to finish it?
I think so. Just that J then equals abc. Right?
Yes. Assuming you mean ##\left |\frac {\partial(x,y,z)}{\partial(u,v,w)}\right|##. So you get ##abc## times the volume of the unit sphere, which you already know.
I'm not too familiar with the notation. So just to be sure. If I saw we have x=f(u), y=g(v), z = h(w) then is what you wrote equivalent to determinate of
fu fv fw
gu gv gw
hu hv hw
? Sorry, I still can't figure out how to write matrices in this forum.
fu fv fw
gu gv gw
hu hv hw
Yes. Right click on this to show the tex:$$
J = \left |\begin{array}{ccc}
a & 0 & 0\\
0 & b & 0\\
0 & 0 & c
\end{array}\right| = abc$$
Alternatively, you can use a Tex editor. I've found Daum equation editor (a free Chrome app) to be excellent for complicated Tex formatting.
  • · Replies 0 ·
15K
