Light’s temperature and particle’s temperature from 3000K
  • Context: Graduate
  • Thread starter Thread starter nonspace
    Temperature
The discussion centers around the temperatures of light and particles in the universe, particularly focusing on the implications of the universe's thermal equilibrium state at approximately 3000K and how this relates to the current temperature of the cosmic microwave background (CMB) at 2.7K. Participants explore the temperature of particles in the intergalactic medium and the effects of adiabatic expansion, as well as the complexities introduced by interactions between matter and radiation.
  • Some participants discuss the FLRW metric and its implications for energy density and pressure in a photon gas, noting how the expansion of space affects photon wavelengths and energy density.
  • There is a proposal that the temperature of the universe dropped from 3000K to approximately 2.73K due to the expansion factor of about 1100.
  • One participant clarifies that their interest lies in the temperature of matter in the intergalactic medium, rather than radiation temperature.
  • Another participant suggests that while adiabatic expansion applies, the non-uniform distribution of matter and interactions with radiation complicate the temperature distribution, leading to variations in temperature across different regions.
  • There is a discussion about the assumptions involved in using classical thermodynamics to derive the temperature of matter, with some participants suggesting that nuclear reactions in stars must be considered, as they contribute heat to the system.
  • One participant mentions the potential influence of dark matter and its unknown properties on the temperature of the universe.
  • A request for recommendations on literature regarding the age of the universe at the time of recombination is made, indicating interest in further reading on the topic.
Participants express multiple competing views regarding the temperature of matter in the universe and the assumptions underlying their calculations. There is no consensus on the exact methods or models to derive the current temperature of intergalactic matter, and the discussion remains unresolved.
Limitations include the dependence on assumptions about the uniformity of matter distribution, the effects of nuclear reactions, and the role of dark matter, which are not fully resolved in the discussion.
nonspace
The universe is estimated to have been in the thermal equilibrium state(3000K) around 380,000 years after its birth.
From this, we induce the current temperature of CMB - 2.7K.
In case of particles existing outside(example. at Void area) of the cluster of galaxies structure (or, if not affected by local heat source), what is the temperature currently predicted? How can we get the real answer?
Is it adiabatic expansion? How can we get the real answer?
Have a nice day!
Space news on Phys.org
Hi.
You have to start with FLRW metric
[itex]\delta s^2 =\delta t^2 - a^2(t) \delta S^2[/itex]
and solve Einstein equations. These give You 2 equations regarding energy density [itex]\rho[/itex] and pressure [itex]p[/itex] as functions of scale parameter [itex]a(t)[/itex]. One of them is
[itex]\dot \rho = -3 \frac{\dot a (t)}{a(t)} \left( \rho +p\right)[/itex]
For photon gas, [itex]p_R=\rho_R /3[/itex] for statistical reasons. So when calculated, it turns out that density [itex]\rho[/itex] of photon gas behaves as
[itex]\rho_R = 1/a^4 (t)[/itex]
Density [itex]\rho_R[/itex] is not [itex]1/a^3 (t)[/itex] as one might expect, because photon wavelengths are elongated because of space-time expanding. Expansion scale factor being [itex]a(t)[/itex], calculated density seems right.
So all photons emitted back then lost their energy by now by factor [itex]1+z=a_0 / a(t)[/itex] due to expansion of space.
When everything is calculated through, factor [itex]1+z[/itex] turns out to be about 1100. So temperature dropped from around 3000K to 3000K/1100=2,73K.
It is not so trivial to show that age of universe back then was 380 000y at the time of creation of atoms when photons stopped scattering off free particles and became free. You can check any book on Cosmology to find more details on it. Calculations involve cross sections for electron to be captured in hydrogen and so on. I can elaborate it if You want to - if You can't download any recombination/decoupling reading from net. Explanation requires knowledge of quantum mechanics II and thermodynamics of fermions.
However, You can calculate [itex]1+z[/itex] easily once You know the age of emission of photons. We use the second equation coming from solving Einstein equations:
[itex]\frac{\ddot a (t)}{a(t)}=-\frac{4 \pi}{3} \left( \rho + 3p \right)[/itex]
After decoupling of matter and radiation, universe became matter dominated. So [itex]\rho[/itex] for previous equation is [itex]\rho_M[/itex]. It decreases as [itex]\rho_M=1/a^3 (t)[/itex], with [itex]p_M =0[/itex] due to matter becoming non-relativistic. So equation to solve is
[itex]\frac{\ddot a (t)}{a(t)}=-\frac{4 \pi}{3} \frac{1}{a^3 (t)}[/itex]
Solution is [itex]a(t)=t^{2/3}[/itex] up to a constant factor. Hence [itex]t_0[/itex] being 13,4Gy and [itex]t[/itex] being 380 000y at decoupling, one finds [itex]1+z=1100[/itex].
Bianchi relations for FLRW metric are first law of thermodynamics. Yes, expansion is adiabatic: there is no energy transfer, because there is no communication possible with whatever lies outside of our particle horizon.
I hope this helps.
Cheers.
Dear Kraflyn!
Thank you very much!
I’m sorry. I apologize for my poor English.
My question is not radiation’s temperature but matter’s(intergalactic medium’s) temperature.
How do derive it from thermal equilibrium state(3000K)?
It would be an adiabatic expansion, too. However, matter interacts with other matter and with radiation (e.g. from stars), its distribution is not so uniform and so on. The result is that there are very hot areas, and even a few areas which are colder than the CMB. See Wikipedia for more information.
Hello.
You're welcome.
Ah, I see Your point now. Yes just apply adiabatic expansion law together with the usual equations of classical thermodynamics. Matter became non-relativistic at recombination and universe entered matter dominated era. So the usual classical thermodynamics holds. You may take matter to consist purely of hydrogen. This is just a theoretical assumption: the hydrogen assumption. You probably know there is some exotic kind of ordinary matter hidden in space, called Dark Matter. The weakly interacting matter. So maybe there is more than just hydrogen. So if You suppose it's just hydrogen, then
[itex]pV^{\kappa} = const.[/itex]
[itex]pV=NRT[/itex]
[itex]\kappa = 1,4[/itex]
should bring You there. The result is lower than 2,7K. So this approach has some wrong assumption in it. The capital wrong assumption is that matter forms a gas. Furthermore, this approach does not take nuclear reactions in stars in account. Heat is being produced in nuclear reactions, so adiabatic assumption for classical matter falls badly. Matter is clustered, so no gas. Plus Dark matter might behave in some unexpected way too. So You might wish to start with adding heat from nuclear reactions. I'd say one may take all hydrogen to be active in stars, so one should: A) calculate power radiated in nuclear reactions or B) read some data on net on it, and then make an average over entire horizon. We know mass of matter in visible universe, so we indirectly know number of hydrogen atoms. All that is required is mean temperature of a star. I don't have such data right here= in front of me, of course. However, one way to find out about the temperature of mass is like described. Interestingly: You can do it without knowing about 3000K or 380 000y. It might be interesting to relate recombination to energy released through nuclear reactions. This would relate number of hydrogen atoms to 3000K and early universe. I believe we don't have such relation yet so far.
This means, You can safely discard any information You might get from classical thermodynamics. The interesting part comes from stars. Temperature comes from nuclei.
Keep us informed.
Cheers.
Dear Kraflyn,
Thank you very much! I really appreciate your explains.
Kraflyn said:
... It is not so trivial to show that age of universe back then was 380 000y at the time of creation of atoms when photons stopped scattering off free particles and became free. You can check any book on Cosmology to find more details on it. ...
Kraflyn, would you recommend any particular book / source specifically in relation to dating the age of the universe at this point (i.e. at 380 000y)?
Regards,
Noel.
  • · Replies 23 ·
  • · Replies 0 ·
  • · Replies 19 ·
