Do hydrogen atoms continuously emit radiation?
The discussion revolves around whether hydrogen atoms continuously emit radiation, particularly focusing on the behavior of electrons in quantum states and their interactions with radiation. Participants explore concepts from quantum mechanics, classical physics, and the implications of synchrotron radiation.
  • Some participants question if an electron in a hydrogen atom continuously emits or absorbs radiation, particularly when considering its behavior as a point charge in a 1s wave function.
  • Others argue that an electron in the ground state does not emit energy, emphasizing that classical concepts of orbits and acceleration do not apply in quantum mechanics.
  • There are claims that electrons do not radiate intrinsically and that any radiation occurs due to external energy absorption, such as from the cosmic microwave background.
  • Some participants suggest that the quantization of energy levels prevents continuous radiation emission, leading to stable orbital configurations.
  • Discussions also touch on the nature of synchrotron radiation and its description in both classical and quantum frameworks, with some participants seeking clarification on how these concepts relate to atomic behavior.
  • There are references to the historical context of quantum mechanics arising from the need to explain atomic stability without continuous radiation emission.
Participants express multiple competing views regarding the emission of radiation by hydrogen atoms, with no consensus reached on whether electrons emit radiation continuously or under specific conditions. The discussion remains unresolved with differing interpretations of quantum mechanics and classical physics.
Participants highlight limitations in applying classical physics concepts to quantum systems, particularly regarding acceleration and radiation. The discussion also reflects on the complexities of energy states and the stability of atomic structures.
what_are_electrons
Three (3) Questions:
1. Keeping in mind the light emitted by Synchrotrons, then taking the electron as a point charge, and assuming that it orbits the proton in accord with a proper 1s type wave function, does that electron continuously emit (and/or absorb) radiation other than virtual pairs even if it is for time < 10(-18) sec?
2. If it does emit radiation, then what energy level, if any?
3. If so, from where does the atom get the energy to maintain that quantum state?
Three answers:
1. If an electron is in the ground state (i.e. energy eigenstate corresponding to the lowest allowed energy level = 1s) it will not emit any energy. Realise that the electrons aren't orbiting the nucleus in any classical sense.
2. See above. Also, the radiation doesn't have an "energy level". Energy levels are different energies corresponding to some energy eigenstate, usually in an atom.
3. See answer 1, the electron does not emit any energy. You must realize that the classical equations do not apply.
At the most elementary level (assumed by Schrödinger's equation),the total energy of the atom is composed by the KE from the electron(s) and nucleus + the electrostatic Coulomb attraction+repulsion terms...
Daniel.
Electrons undergoing acceleration emit radiation in a synchrotron. Right? Does the electron in the hydrogen atom undergo acceleration or not? If it is being accelerated continuously, then why doesn't it emit radiation?
Yes.
No.Acceleration is a classical concept.It does not pertain to the quantum world,hence cannot be used in the (quantum mechanical) description of matter.
Because the energy levels are quantized...?? :confused: :wink:
Daniel.
dextercioby said:
Yes.
No. Acceleration is a classical concept. It does not pertain to the quantum world,hence cannot be used in the (quantum mechanical) description of matter.
Daniel.
OK. Then I should understand that the light emission by the electrons in the synchrotron is best described by QM. If so, please elaborate a bit. Thanks.
Synchrotron radiation is described with satisfactory results both at classical level (relativistic CED) and at quantum level (QED,not QM).The differences are fundamental and come from the classical,respectively quantum description of both the particles accelerated and of light.
This is the simplest picture it can be given under these circumstances.
Jackson's book and a book on QED (e.g.Ahiezer & Berestetzkyy,Jauch & Rohrlich) could provide the necessary (mathematical) details and the physical interpretation of results.
Daniel.
I thought everything, hot or cold, emits radiation.
I know what u're referring to,but the discussion was around quantized energy levels of atoms and the electrons being in pure stationary states in which they do not emit any radiation (classical or quantized) whatsoever.Atoms are neither cold,nor hot...
Daniel.
In QM, we usually make the connection with classical physics by way of expectation values of physical quantities. When the electron is in one of hydrogen's "energy levels," it is in what we call a stationary state, in which the probability distribution of the electron's position does not change with time. This means that the expectation value of position, <x>, does not change with time. In that sense, we can say that an electron in a particular energy level is not in fact accelerating.
To carry this interpretation further, when an electron is in the process of making a transition from one energy level to another, its Schrödinger wave function can be represented as a linear combination of the wave functions for the initlal and final states:
[tex]\Psi = a \Psi_{initial} + b \Psi_{final}[/tex]
where a and b vary with time so that before the transition begins a = 1 and b = 0, and after the transition ends a = 0 and b = 1. It turns out that <x> is not stationary for this wave function; it oscillates in time, with a frequency that is equal to the frequency of the light emitted in the transition! In this case we can consider the electron to be accelerating, and emitting radiation as a result.
Atoms do not radiate intrinsically. If they did, they would lose mass and evaporate. They do, however, reradiate energy they absorb from their surroundings. Since the CMB temperature is presently 2.7K, there is still enough free energy to power this effect.
Electrons are bound to the atomic nucleus by a Coulombic potential. Some people think that due to this Coulombic interaction, the electrons are accelerated and therefore they must radiate continuously. This is wrong (the radiation part that is) because the orbitals (the regions where you can find a certain electron at a certain energy-state) are stable. To see this, just imagine this: when an electron is close to the nucleus, the Coulombic interaction is stronger, yielding a potential energy that is smaller (more negative). However, the kinetic energy of such electrons is bigger. So electrons that are close to the nucleus have a lower potential energy but they move faster in the orbitals, yielding a higher kinetic energy. When looking at electrons that are firther away from the nucleus, the potential energy rises and the kinetic energy lowers. In the end, these two effects of energy will yield a stable situation. Therefore, there will be no radiation.
regards
marlon
this is due to the equilibrium in energy of the electrons. read the example of my above post.
marlon
To rescue atoms continuously emitting radiation we had to invent a whole new theory of the universe. This was one of the greatest motivations for QM!
If the electron orbited the proton, then yes, it would emit radiation
because an accelerated charge emits radiation. But that would also mean it loses energy, namely kinetic energy. What happens?
Well, the electron would crash into the proton and hydrogen wouldn't exist (hmm...
what's actually so bad about an electron crashing into the nucleus, lol. Why's there
no hydrogen where the electron is sticked together with the nucleus?)
That's why the 'planet model' isn't really good.
My teacher once said: 'You shall not make for yourself a carved image of the atom'
(one of the ten commandments).
Unfortunately that implies that you can't really say what an atom looks like.
dextercioby said:
Yes.
No.Acceleration is a classical concept.It does not pertain to the quantum world,hence cannot be used in the (quantum mechanical) description of matter. Because the energy levels are quantized...?? :confused: :wink:
Daniel.
Does this mean that electrons that are linearly or circularly accelerated (like at SLAC or CERN or KEK etc.) can not be described with QM?
They can,but the theory which does,if it's a quantum theory (it may not be,it may simply be SR),will not use the word and the concept "acceleration".
Daniel.
At RT most atoms on the Earth have kT of energy, about 0.025 eV. Would all atoms have that energy available for use? Is that more than the microwave BG?
regards
marlon
This seems to contradict XPS results that show that the 1s electron clearly has the largest BE (in effect PE), The heaviest atoms have 1s BE >90,000 eV. All other electrons have lower BE as their radius increases.
Your whole previous post denotes not knowing the basic Bohr model of (H) atom,not to mention the QM model.
My advice is,please read... :smile:
Daniel.
Again i must agree with dextercioby on this one...
marlon
Daniel.
Am reading as fast as I can, but, alas, my normal job slows me down.
The PhD was org chem, but my work (20 yr+) is surface analysis (XPS, Auger, AFM ...). Have indeed studied the AP & QM of my time (1975-79). My efforts on this forum are to get a refreshed and up-to-date grip on the conceptual basics of atomic physics and related matters so I can progress my efforts to learn AP etc. Your efforts, kindness and bantering are most appreciated. Thanks! Hope I can count on your continued patience, but feel free, as I'm sure you will, to slap my words as needed. Best regards always!
Vince
If I understand correctly, so far there are 2 ways for at atom to radiate.
1.Electrons absorb and re-radiate the energy they once absorbed. And this energy is conserved right?
2.Another situation, is that an "accelerated electron(charge)" (being altered from it's eigenstate) would radiate energy as well. So what is an example of an accelerating electron?
  • · Replies 38 ·
  • · Replies 18 ·
