Is Cable Length a Factor in Determining Coaxial Cable's Power Rating?
The discussion centers around the factors influencing the power rating of coaxial cables, particularly the role of cable length in relation to heat transfer parameters and attenuation. Participants explore theoretical and practical aspects of power dissipation and thermal management in coaxial cables.
  • One participant calculates maximum power based on heat transfer and suggests that cable length affects power rating, despite data sheets indicating otherwise.
  • Another participant emphasizes that power rating depends on operating frequency, thermal environment, and VSWR, suggesting that length may not significantly impact the overall power rating.
  • A different participant acknowledges the uneven power dissipation along the cable, noting that the front end dissipates more power and questions the implications of length on thermal resistance and attenuation.
  • One participant argues that EM power decreases exponentially with distance, implying that heat loss per unit distance also decreases, which could mean that length dependency is negligible.
  • Another participant proposes a numerical approach to visualize the power distribution along the cable using potential dividers, suggesting that the established data sheets may be reliable.
Participants express differing views on the impact of cable length on power rating, with some suggesting it is a factor and others arguing that it is not significant. The discussion remains unresolved regarding the influence of length on power ratings.
Participants mention various assumptions, such as the dependence of thermal power dissipation on length and the nature of attenuation, which may not be fully addressed in the existing data sheets.
TheEggo
I am trying to calculate the maximum power of a coaxial cable, based on heat transfer parameters and limiting temperatures of cable components. I've determined that a certain heat load on the conductor surface (in Watts per inch of cable) will put the dielectric above its operating temperature.
I am having trouble turning that heat load number into a power rating (I'm looking at attenuation numbers). Would a power rating be dependent on cable length? My calculations suggest that length is a factor, but every data sheet I look at disagrees.
Hi
You would probably find what you need in the detailed spec of the cable. The power rating of a cable will ultimately depend upon the actual operating frequency (the loss is frequency dependent), the thermal environment of the cable (clearance between cables and ambient temperature) and even the VSWR on the cable. But the manufacturer will have a conservative spec, which would be the one to use unless there is a really good excuse - e.g. cost or available duct space.
I couldn't be sure how W/inch would help (except for a very short piece of cable) as the thermal power dissipated externally AND the RF power dissipated internally would both be proportional to length - so the equilibrium temperature would be the same). Needless to say, it would be the start of the cable run where the most power would be dissipated. Once you were 3dB down, the power dissipated would be halved.
Interesting. I had been assuming that the power would be dissipated evenly over the length of the cable. What you said makes sense now that I understand attenuation more. So the front end (power-in end) will dissipate more power.
I'm still hung up on the effect of length. Thermal resistance and power dissipated externally are linearly dependent on length. Attenuation (in dB) is also linearly dependent on length, but it is a logarithmic ratio, so it seems to me that the length dependency doesn't wash out? I can post my math if that is not clear.
Every cable data sheet I can find lists a power rating as independent of length, either I'm doing it wrong or they made an assumption or two.
Think like this. The EM power will decrease exponentially with distance along the cable. This means that the power loss will also decrease exponentially so the heat loss per unit distance will also decrease at the same rate. The heat transferred away will be proportional to temperature difference and the temperature difference will decrease as you go further along the line. (i.e. the length dependency will "wash out").
This is the same situation as with radioactive decay and Capacitor discharge, the one one variable is the differential of the other and, with exponentials, the derivative is the same as the function- the rate of change is proportional to the value.
You could prove it to yourself numerically by drawing the cable out as a series of potential dividers - each one giving the same fraction as the previous one. You always have a 49Ω source, a 49Ω output load and a 1Ω series resistor 'at the top end' of the potential divider- and the 49Ω load becomes the source for the next potential divider etc. etc.. Crude but it would work, I think.
Plus, 50 thousand data sheets can't be wrong. haha
Are you free to revisit this? I sent you a private message.
  • · Replies 16 ·
  • · Replies 23 ·
  • · Replies 81 ·
11K
  • · Replies 19 ·
