Heat is just kinetic energy at a molecular level, right?
The discussion centers around the relationship between temperature and molecular motion, specifically how molecular velocity changes with temperature in the context of kinetic energy and thermodynamic principles. Participants explore concepts from statistical mechanics and the equipartition theorem, addressing both theoretical and practical implications.
  • One participant questions the speed of molecules at 1 kelvin and how it changes to 2 kelvin, expressing uncertainty about the relevance of density.
  • Another participant asserts that density is not important for relating macroscopic phenomena to atomic events and introduces the equipartition theorem to explain the relationship between temperature and molecular velocity.
  • A different participant agrees with the previous equation but emphasizes the need for packing density to determine individual molecular mass and velocity, noting that velocity increases with the square root of temperature.
  • One participant asks for clarification on the units of velocity in the context of the discussed equations.
  • A later reply clarifies that the equipartition theorem provides the root mean square (rms) velocity of particles in thermal equilibrium, not the velocity of a single particle, and discusses the implications of temperature changes on rms velocity during heating.
Participants express differing views on the importance of density in the context of molecular motion and the applicability of the equipartition theorem during temperature changes. There is no consensus on the implications of heating a system while it is not in thermal equilibrium.
Participants highlight the distinction between average kinetic energy and individual particle velocities, as well as the limitations of applying the equipartition theorem during non-equilibrium conditions.
LastTimelord
Assuming a density of exactly 1 g/cm3 (assuming that even matters)
So, at 1 kelvin, how fast do the molecules actually move? Is it a direct, or exponential increase to 2 kelvin?
This might be a stupid question. I'm not a scientist.
Density does not matter. Relating macroscopical phenomena of thermodynamic equilibrium to atomic level events was subject to much research and is legitimate scientific question. Quick was to relate temperature and velocity of a particle is through equipartition - let say you have pointlike atoms. For every degree of freedom - number of independent ways particle can move - you get 1/2kT of kinetic energy. Such particle has 3 degrees of freedom, so
3*1/2kT = 1/2 mv2
where k is Boltzmann constant, T is temperature in kelvins, m is mass of a particle and v is the thing you are interested in - velocity of a particle.
The previous post is correct in the equation given; however, the density is actually useful but we need one more piece of information, the packing density of molecules (i.e. number of molecules per unit volume). With that number, you can determine the mass of of an individual molecule and thus the velocity.
Regardless, it's clear from the equation that velocity increases as the square root of temperature. So increase the temperature by a factor of 100, the velocity increases by a factor of 10.
This equation is very helpful, but what would the unit of velocity be in this case?
3*1/2kT = 1/2 mv2
Just to be very clear, the equipartition theorem does not give you the velocity of a single particle, it gives you the root mean square (rms) velocity of the atoms of an ideal gas in thermal equilibrium at temperature T. In this case, where all of the atoms are the same (i.e., have the same mass and are classical particles), it follows that this is the rms velocity of a single atom, but that atom could at times be going much faster or much slower than the rms velocity.
That is to say, temperature is related to the average kinetic energy.
Also, it's worth noting that when one asks how the rms velocity increases with temperature, the word "increases" is a bit misleading. The equipartition theorem relates, for example, the rms velocities and temperatures of two systems in equilibrium, but it only relates the rms velocities and temperatures of a single system at different points in time when the system is in thermal equilibrium at those two points in time.
That is, you can use it relate the rms velocity of a system in equilibrium at temperature ##T_1## at time ##t_1## compared to its rms velocity at a later time ##t_2## and temperature ##T_2##, but only so long as you have waited for the system to settle back down into equilibrium. The equipartition theorem does not hold while you are heating the system from temperature ##T_1## to ##T_2##; i.e., while the temperature is actually increasing - hence why I say "increasing" is a misleading word to use.
So, you can relate the rms velocities and temperatures of two different systems in equilibrium, or you can relate the rms velocities and temperatures of a single system that is in equilibrium at different temperatures at different points in time, but you can't do that while you are actually physically increasing the temperature.
  • · Replies 0 ·
  • · Replies 19 ·
  • · Replies 41 ·
  • · Replies 23 ·
