Failure to understand a basic integral application
The discussion revolves around the application of integrals to calculate the total mass of a mass distribution along a line, where the mass at each point is defined by a linear function. Participants explore the correct method for summing individual masses and the implications of using integrals in this context.
  • One participant presents a method of summing masses by dividing the line into segments and calculating mass at each point, but questions their reasoning.
  • Another participant suggests that the initial summation approach is incorrect and proposes a formulation involving the product of mass density and segment length.
  • A participant raises a concern about the nature of mass distribution, questioning whether it should be treated as infinite if each point has mass.
  • Another participant corrects the initial assumption about the summation of indices, stating that the sum of integers does not equal the total length of the line.
  • Some participants discuss the transition from summation to integration, emphasizing the need for limits as the segment length approaches zero.
  • There is a suggestion that the problem's rigor could be improved by referencing basic mathematical texts instead of relying solely on forum discussions.
  • One participant reiterates the importance of correctly approximating mass in small segments and outlines a more detailed approach to arrive at the integral formulation.
Participants express differing views on the correct method for calculating total mass, with no consensus reached on the best approach. Some agree on the need for integration, while others challenge the assumptions made in the initial reasoning.
Participants note limitations in the initial problem setup, including the treatment of mass distribution and the assumptions about segment lengths. The discussion highlights the complexity of transitioning from discrete summation to continuous integration.
cantRemember
I will show you my (obviously wrong) way of thinking when i have to apply an integral.
Please correct me where I'm wrong.
(imaginary question)
Suppose you have a mass distribution across a line, where the mass of each point is given by the equation f(x)=a*x (assume a is a constant)
find the total mass, if the line is c meters long (beginning @ x=0)
(My stupid train of thought)
We have to add up all the individual masses on the line.
so divide the line into n segments, calculate the mass for each one and add them up
f(x1)+f(x2)+...+f(xn)=
a*x1+a*x2+...+a*xn=
a(x1+x2+...+xn)=
a*c
What am i doing wrong?
(Besides the language use, I'm not a native and have little experience in such teminology)
I think first line (f(x1)+f(x2)+...+f(xn) =) is alredy wrong.
I think you shoud write it like this:
f(x1)*Δx+ f(x2)*Δx+f(x3)*Δx+f(x4)*Δx+...+f(xc)*Δx=
Try to calculate using this expresion.
Although something else is weird at this example. Ussualy, that kind of examples give the function of density and not mass. If each point has some nonzero mass on some interval, that the whole mass on the interval should be infinity. Correct me if I am wrong.
@cantRemember
Your mistake is when you go from
"a(x1+x2+...+xn)="
to
"a*c"
the Sum of the integers 1+2+3+4+...+n
is NOT c
it's c(c+1)/2 (ultimately the area of a triangle - not the length of the rod).
You could get the right answer using
ax1 +a(x2-x1) +a(x3-x2) +a(x4-x3) + .. + a(xn-xn-1)
which would be adding up the masses of the individual lengths. This, of course, simplifies into a xn
which is the value ac you wanted!
But shouldn't be that infinity, since we have an infinity mass points?
That would be the next step in the argument - i.e. going from a simple summation to an integration. The OP has not gone as far as to take the limit as Δx→0. In that case, the answer is still ac, where a is the mass per unit length.
it's correct that the problem of infinity will arise when we take limit n-> infinity... I think cantRemember is looking for a way to look at his simplified version of the problem...
so if we divide the length c into n segments (each segment of length c/n) and assume that the mass of segment number i is f(xi) = a*xi, where xi is the coordinate of the center of the segment, then...
total mass = f(x1)+f(x2)+...+f(xn)
= a*x1+a*x2+...+a*xn
= a(x1+x2+...+xn)... (cantRemember is right till here)
= a*c/n * (1+2+3+...+n)... (what sophiecentaur said)
= a*c/n * n*(n+1)/2 ... (the summation in the brackets will not give c*(c+1)/2)
= a*c*(n+1)/2
NOT a*c
sophiecentaur's solution would be correct if in f(x) = a*x, x is the length of the segment under consideration and not the x co-ordinate of the segment
This thread is not being rigorous enough, I think. It would be far better to start with some basic Maths and a book would be a better way through. Question and answer doesn't deal with this sort of thing very well as the threads ramble far too much..
I am not sure that I actually answered the question he posed and I may have added confusion. Step by step through a page of book-work would sort it all out.
a*x1+a*x2+...+a*xn=
a(x1+x2+...+xn)=
a*c
The mistake is in how you add "all the individual masses". In any of your segments, there are infinitely many of them, so you cannot just take one value of f(x) at the end of a segment.
Instead, you assume that the segment is so small, that f(x) does not change much in it, then the max of the segment can be approximated by the length of the segment multiplied by the value of f(x) somewhere in that segment. So you end up summing these: [itex]f(\xi_i)(x_i - x_{i - 1})[/itex], where [itex]\xi_i \in [x_{i - 1}, x_i][/itex]. Because you assume that f(x) does not change much in a segment, you can just take [itex]x_i[/itex] for [itex]\xi_i[/itex], so we will sum [itex]f(\xi_i)(x_i - x_{i - 1}) = ax_i(x_i - x_{i - 1})[/itex]. You can further take all the segments to be of the same length [itex]d = (B - A)/N[/itex], where [itex]A[/itex] and [itex]B[/itex] are the limits of integration, and [itex]N[/itex] is the number of segments, thus getting the sum of [itex]f(\xi_i)(x_i - x_{i - 1}) = ax_i(x_i - x_{i - 1}) = a(A + di)(d)[/itex]. Putting all together, the integral then becomes [tex]\sum_{i = 1}^{N}ad(A + di) = ad\frac N 2 (A + B)[/tex] because it is just the sum of arithmetic progression, and plugging there the definition of [itex]d[/itex] you obtain [itex]a\frac {B^2 - A^2} {2}[/itex].
In this particular case we did not actually have to go to the limit of the sum with N growing infinitely, but that is because f(x) was linear. With more complex functions, we would have to.
