Integrate d/dx f(x) with respect to x
  • Thread starter Thread starter brushman
    Integrate
The discussion revolves around the integration of the derivative of a function, specifically the case where d/dx f(x) = 0. Participants explore the implications of integrating both sides of this equation and the interpretations of the results.
  • Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants examine two methods of integration and question the validity of the results. There is confusion regarding whether the left side simplifies to f(x) or f(x) + a constant. Some participants suggest that both methods might yield equivalent results, while others emphasize the need for clarity on the constants involved.
There is an ongoing exploration of the implications of integrating the derivative of a function. Some participants have pointed out potential errors in reasoning, particularly regarding the integration of zero and the interpretation of constants. The discussion remains active with various interpretations being considered.
Participants are navigating the nuances of indefinite integrals versus definite integrals and the implications of linearity in integration. There is a mention of Riemann sums, which adds complexity to the discussion about the nature of the integral in this context.
brushman
Suppose I have d/dx f(x) = 0, and I integrate both sides with respect to x. I have worked out two possibilities, and I am not sure which is correct:
1) ∫ d/dx f(x) dx = 0 → ∫ f'(x) dx = 0 → f(x) + C = 0
or
2) ∫ d/dx f(x) dx = 0 → d/dx ∫ f(x) dx = 0 → d/dx (F(x) + C) = 0 → f(x) = 0
where F(x) is the integral of f(x) and f'(x) is the derivative of f(x), both with respect to x.
Thanks.
Neither looks right to me. When you start with
$$\frac{d}{dx} f(x) = 0,$$ integrating both sides gives you
$$\int \frac{d}{dx} f(x)\,dx = \int 0\,dx.$$ The righthand side isn't necessarily equal to 0.
Oh, so the indefinite integral of 0 gives you a constant. So I'm still confused with if the left side simplifies to f(x), or f(x) + a constant.
Besides the fact that I improperly integrated zero, I don't see any errors on the left side of my evaluations. Perhaps they are both correct, but method two gives you more information about the original function f?
It doesn't matter whether the left side gives a constant or not. The right side does give a constant that is not generally the same as the one on the left side. However, it can be shown that only one constant is needed.
Can you show that?
Thank you. I can see that the results are equivalent since you can combine the two different constants into one, but wanted to verify my math was correct otherwise.
Doesn't this violate linearity of the integral? If we have ∫0dx , then use 0=0.0 , so
∫0dx =0[∫0dx] =0
Moreover: If we used the perspective of Riemann sums, then ∫0dx is the area under
a curve with height zero. And ∫0dx=∫(c-c)dx=∫cdx-∫cdx.
∫0dx =0[∫0dx] =0
This is an indefinite integral (i.e. it's an anti-derivative), it's not a definite integral, so the Riemann sum comment doesn't apply here.
But how about the linearity part: isn't the indefinite integral linear? I understand
the idea: for any constant function f(x)=c , f'(x)=0 , and the converse, but I think
there are problems with the layout.
  • · Replies 105 ·
13K
