How to figure out the pressure when you pick up a cup upside down in water
  • Context: High School
  • Thread starter Thread starter JayRad
    Figure Pressure Water
The discussion revolves around the pressure dynamics involved when a cup is turned upside down in water, particularly focusing on whether fish can swim into the cup and how to measure the pressure in this scenario. It includes theoretical considerations, practical applications, and experimental ideas related to aquarium design.
  • Experimental/applied
  • One participant questions the pressure dynamics when a cup is lifted upside down in water, wondering if fish can swim into it and how to measure the pressure.
  • Another participant states that the pressure at the top of the cup is lower than atmospheric pressure, while the bottom is equal to atmospheric pressure, suggesting that fish should be able to swim into the cup without issues.
  • A later reply mentions that there is a maximum height before a vacuum forms at the top of the cup, which could affect the fish's ability to approach that limit due to potential lack of dissolved oxygen.
  • Participants discuss the implications of a negative gauge pressure in a proposed aquarium design, questioning whether this would lead to dissolved oxygen being released from the water and forming air bubbles.
  • One participant calculates that a tube would need to be about 10.1 meters high to form vapor, suggesting that typical setups would not reach this height and thus not create significant vapor pressure issues.
  • Another participant argues that while vapor formation may not be a concern, air bubbles could still form due to low pressure, especially with a bubbler maintaining oxygen levels in the water.
  • A participant shares a personal anecdote about successfully building a similar aquarium setup, noting that fish were reluctant to swim through the tube, possibly due to pressure differences or the exposed feeling of the design.
Participants express a mix of agreement and disagreement regarding the pressure dynamics and the effects on fish swimming into the cup. While some agree on the calculations regarding pressure, others raise concerns about the implications of low pressure and oxygen levels, indicating that the discussion remains unresolved.
There are limitations regarding assumptions about pressure dynamics, the behavior of dissolved gases, and the specific design of the aquarium setup. The discussion does not resolve these complexities.
JayRad
Pressure of water in upside down cup
We all played with a cup in a body of water, you know when you put it in water, turn it upside down and lift above the water level and the cup holds the water in, until you get above the water surface... So say you did that in a fish tank, could the fish swim up the cup, if you held it still, or is there too much pressure, and how would you measure that pressure? Please help I have no idea how to figure this out.
The pressure in the top of the cup is actually lower than atmospheric pressure. At the bottom of the cup, the pressure would be equal to atmospheric pressure (assuming the top of the cup is on the surface of the water). A fish should be able to swim into the cup with no problems.
The pressure at the top of the cup can be calculated by
[itex]\displaystyle P=101 kPA - \rho g h[/itex]
h is the height of the cup, 101 kPA is atmospheric pressure, and ρ is the density of water (1000 kg/m3). g, of course, is the gravitational acceleration on Earth's surface.
I can't beat that reply but perhaps worth adding that the equation implies a maximium height before a vacuum forms at the top. The fish might have a problem approaching that limit that as there might be no disolved oxygen in the water?
It might be fun building an aquarium with an arch shaped tube that would allow the fish to travel up one side and back down the other.
That aquarium idea does sound quite interesting.
I wonder though, with the water column (tube-arch) constantly drawing a negative (gauge) pressure, would it do as you said & cause the dissolved oxygen in the water to come out here?
That would cause an air bubble to form, slowly displacing the water in the arch, while also de-oxygenating the water.
If so, you'd need a good bubbler to keep up (keep the fish happy), as well as a way of periodically removing the trapped air (syringe & tubing).
Might want to do a simple test setup first, as a proof of concept.
At room temperature, the vapor pressure of water is about 2 kPA. Doing a quick calculation, this means that in order to form vapor in the tube, the tube would need to be about 10.1 meters high; so unless you plan on having an extraordinarily high tube for the fish to swim through, you won't need to worry about forming vapor at the top.
This is the same reason I neglected to mention the maximum height for the equation I posted above. I figured the cup isn't going to be anywhere near 10 meters tall, which is when the pressure at the top starts to approach 0.
I believe dissolved oxygen works slightly differently than the vapour partial pressure.
While I agree (& thank you for looking up the value) that you wouldn't be forming a large vapour bubble (essentially room temperature steam) for a short tube, I still think an air bubble may form (albiet slowly).
With a bubbler constantly trying to add air to the water (keeping it at the saturation point for room temperature/pressure), a low-pressure area would seem to invite rejecting disolved gas (like coming up from a dive).
If I'm completely off base with the above, I'd still say fish breath could collect there over time, so design for maintenance :)
Yes, you can build this. My brother did it with his fish tanks, forming an arc that reached from one tank to the other by sticki ng up out of the water and over the edge of the tank at one end, and then went across the small space (about a foot, I think) between the two tanks, and down into the second.
After fabrication, he placed the two ends of the device into the two fish tanks, which he had filled much closer to their tops than normal. He then took some clear palstic tubing and slid it down into the water and up into the pipe. Once the end of the tube was in place, he put the other end in his mouth and satrted sucking the air out. Water rose up into the pipe from both ends as the air came out. He had to stop pretty soon, as the water levels in the tanks were getting closde to the ends of the pipe, so the tank needed re-filling.
After repeating this process several times, and I almost entirely filled with water. After that, he made sure that the input and output from the filter work in opposite tanks, to ensure that water was flowing through the pipe. The fish would swim through it, but only reluctantly. We always wondered if it was because of some pressure difference, but thought it was probably because of the exposed feeling.
  • · Replies 17 ·
  • · Replies 17 ·
