What is the Voltage and Power in a Circuit with Current Sources?
  • Thread starter Thread starter Mosaness
    Voltage
The discussion revolves around determining the voltage and power in a circuit that includes current sources and resistors. The problem involves applying Kirchhoff's laws and understanding the relationships between currents and voltages in the circuit configuration.
  • Exploratory, Conceptual clarification, Problem interpretation, Assumption checking
  • Participants discuss the initial attempt to simplify the circuit and apply KCL and KVL. Questions arise regarding the assumption of current flow through resistors and the correct application of circuit laws. There is a suggestion to express one current in terms of another and to reconsider the treatment of resistors in parallel.
The discussion is ongoing, with participants providing guidance on how to approach the problem. There is a focus on clarifying assumptions about current flow and the relationships between circuit elements. Multiple interpretations of the circuit setup are being explored.
Participants are addressing potential misunderstandings regarding the flow of current through parallel resistors and the application of circuit laws. The original poster's assumptions are being questioned, indicating a need for further clarification and exploration of the circuit's behavior.
Mosaness
1. Determine the voltage v as labeled in Fig. 3.72, and calculate the power supplied by each current source.
KVL and Ohms Law
The first step is to try and simplify the circuit so that it gives a resistance of 0.75Ω, which is obtained by combining the two resistors that are in parallel: [itex]\frac{1}{1 + \frac{1}{3}}[/itex]. We thus now have a current dependent current source, 3ix, a current source of 2A and a resistor of 0.75Ω, with the total current flowing counterclock-wise.
Using this, KCL can be applied:
-3ix - 2 = 0 so that ix = -2/3
V is then:
(1)(-2/3) + (1)(-3)(-2/3) + (-2)(3) = -14/3The power supplied by each current source then should be:
P(3ix) = (14/3)(2/3) = 28/9
P(2A) = (14/3)(-2) = -28/9
You assumed that the same current flows through both resistors which is not true. Use KCL for the node N to express i1 in terms of ix, and KVL for the blue loop in the attached picture.
ehild
ehild
Based on your diagram i1 = -ix.
As for the inner loops,
Do we combine the two resistors? They are in parallel after all and should give 0.75 ohms no?
And if we know that,
Then by KVL,
0.75(-3ix) -1.50 = 0 and we can solve for ix?
Am I on the correct path?
NO, they are different. The loop is not a physical loop, only a closed path in the circuit, to get the sum of potential differences, which should be zero. How does the potential change across the 3 Ω and the 1 Ω resistors?
ehild
  • · Replies 31 ·
