The baseball pitcher on an asteroid
  • Thread starter Thread starter buzz3
    Asteroid Baseball
The discussion focuses on calculating the maximum size of a spherical asteroid from which a baseball pitcher can throw a ball at 150 km/hr (42 m/s) to achieve various outcomes. For part (a), the escape radius is calculated using the kinetic energy (KE) and potential energy (PE) equations, resulting in a radius of approximately 32,439 meters. For part (c), the radius for a stable orbit is derived from the balance of centrifugal force (Fc) and gravitational force (Fg), yielding a radius of about 45,876 meters. Part (b) requires the application of the potential energy equation PE = mgh to determine the height of 50 km.
  • Understanding of kinetic energy (KE = 1/2mv^2)
  • Knowledge of gravitational potential energy (PE = GmM/r)
  • Familiarity with centrifugal force (Fc = mv^2/r)
  • Basic principles of gravitational force (Fg = GmM/r^2)
  • Study the application of gravitational potential energy in varying heights.
  • Explore the relationship between mass, density, and volume in spherical objects.
  • Learn about the calculations involved in orbital mechanics.
  • Investigate the effects of varying asteroid densities on escape velocity.
Students and educators in physics, particularly those focusing on mechanics and gravitational studies, as well as anyone interested in astrophysics and orbital dynamics.
buzz3
A baseball pitcher can throw a fastball at a speed of 150 km/hr. What is the largest size spherical asteroid of density rho=3 g/cm^3 from which he can throw the ball fast enough that it:
(a) escapes from the asteroid into heliocentric orbit?
(b) rises to a height of 50 km?
(c) goes into a stable orbit about the asteroid?
i think...
KE = 1/2mv^2 (kinetic energy)
PE = GmM/r (potential energy, gravitational)
Fc = mv^2/r (centrifugal force)
Fg = GmM/r^2 (gravitational force)
v = 150 km/hr ~ 42 m/s
rho = 3 g/cm^3 = 3000 kg/m^3
M = rho*V
V = 4/3*pi*r^3
(a) make KE = PE and solve for r, which i get r = v*sqrt(3/8*pi*rho*G) = 32439 m
(b) not sure...
(c) make Fc = Fg and solve for r, which i get r = v*sqrt(23/4*pi*rho*G) = 45876 m
Did I do (a) and (c) correctly, and how should I approach (b)? Many thanks!
For part (b) you should use the equation PE=mgh (where m is the mass of the object, g is the gravitational force on the object, and h is the height of the object) You know what the initial kinetic energy is, and that at the peak of the throw; the potential energy will be equal to the the initial potential energy.
I'm afraid that I'm not sure about the other two though...
B uses pretty much the same method as the other two, you just need to find the PE of the baseball at 50 km
