Having trouble explaining this phenomena
  • Thread starter Thread starter charmedbeauty
    Phenomena
The discussion revolves around an experiment to verify Faraday's law by measuring the induced electromotive force (emf) when a magnet is dropped through coils. The original poster reports that connecting two coils in series resulted in the same induced emf as one coil, while connecting them in parallel resulted in half the induced emf compared to one coil. Participants are exploring the underlying physics of these observations.
  • Participants are questioning the relationship between the configuration of coils (series vs. parallel) and the resulting induced emf. Some suggest that the number of loops in a coil might influence the emf, while others are considering the implications of the magnet's motion through the coils. There is also discussion about the average effect of the magnet passing through parallel coils.
The discussion is ongoing, with participants sharing thoughts and hypotheses about the observed phenomena. Some guidance has been offered regarding the need for simultaneous generation of emf in the coils, and there is recognition of the complexity involved in the experimental setup.
Participants are considering the physical arrangement of the coils and the timing of the magnet's passage through them. There is mention of using a voltmeter for measurement, and the potential for misunderstanding due to the sequential nature of the magnet's movement through the coils in series.
charmedbeauty
I was doing an experiment to verify faraday's law
Where we were basically dropping a magnet through a coil and measuring the induced emf
Now here is the thing I can't explain;
we connected 2 coils in series and found the induced emf was the same as that of one coil
then we connected 2 coils in parallel and found that the induced emf was half that when using one coil.
How do you explain this... I thought it had something to do with the resistance but when I checked it using a bit of math for resistance in series and parallel I did not get a result like that from the experiment.
What is happening in terms of the physics here. Thanks
Does it help to think that a single coil is a whole lot of loops joined in series, so to add a whole lot more loops in series should mean the same result - but given the physical size of the set-up, that emf may exist for a longer period of time.
Not sure of the parallel connection.
Yeah I kinda gathered that but I am more unsure of the parallel result... I just can't seem to figure it out.
I wonder if the parallel situation is giving you an "average" result? The magnet can't be in both coils at once [unless one fits inside the other] so at each phase you are getting "emf+0"/2.
One might argue that a magnet falling through a coil effectively produces a power supply, like a battery.
What happens when you connect two similar batteries in Series?
What happens when you connect two similar batteries in parallel?
Well in series the voltages would add and the current capacity would stay the same
in parallel it would be the opposite
so your saying that the ε ≈ dBA/dt
so for ε/2... BA stays the same but the time the battery spends falling through the loop approx. doubles since it is two loops.so N=2n/2l
Is this what your saying?
for the first case (series) it acts like this
2ε = dBA/2dt
thats why we had the same result.
second case (parallel)
ε = 2BA/2dt
2ε = dBA/2dt
ε = 2BA/2dt
I have never actually considered this situation before, so don't have a definitive answer - I merely put forward some thoughts to prod you along.
This last consideration where you refer to rate of change of flux looks promising.
Ok thanks
Can you explain how you went about this? How you dropped a magnet through two parallel coils simultaneously?
the coils were placed on top of each other so the length of the coil (x) is now 2x.
then we dropped the magnet through them so at some point I guess the magnet could have been in both coils at the same time since the length of the magnet was ≈x/2.
does this make sense.
That's how you placed them for parallel coils. How did you place them for series connection?
the same way
charmedbeauty said:
the same way
http://imageshack.us/a/img717/4080/3110y.gif ... there lies your problem.
To succeed in demonstrating what you expect, then the EMFs in each coil will have to be identical, i.e., generated simultaneously. If the magnet has to pass through one coil before it enters the second, then (without careful analysis) it's anyone's guess how the result will pan out.
Were I to do it, I would try concentric windings.
What device were you using to measure the voltage?
just a voltmeter
