| Thread Closed |
Importance of the number 5 |
Share Thread | Thread Tools |
| Sep14-12, 08:44 AM | #1 |
If you notice that there is symmetry in the numbers 0 to 10 this is a good place to start with what I want to talk about.
I want to talk about the circle. If we need a technically correct circle one would need to see the symmetry of 0 to 10 and more correctly 0 to 5 and from this point 10 to 5 in a line. If 10 is our circumference of a perfect circle then we need to find our diameter. We know that there are 4 points in a circle so 2.5 is our diameter. C/d equal pi. Which would be 4 in this case. If you can guide me to where im steering wrong that would be appreciated. I think the question of a circle is symmetry and not a unusual number. |
| Sep14-12, 08:49 AM | #2 |
Hi Jorgy86 - just a bit confused w nature of question re "importance of the number 5"?
| Sep14-12, 08:49 AM | #3 |
I have no idea what you're talking about. Please make yourself clear or this will be locked.
| Sep14-12, 08:54 AM | #4 |
I am trying to explain that there is symmetry in a circle and I'm confused as to why pi is an never ending number. What I want from this thread is an answer to why what I wrote is wrong fx.
| Sep14-12, 08:57 AM | #5 |
| Sep14-12, 09:48 AM | #6 |
Dude, you really need to study some math |
| Sep14-12, 09:54 AM | #7 |
| Sep14-12, 10:01 AM | #8 |
In math there is a concept of a line of symmetry. Where basically you can draw a line through an object and the two sides of the line will be mirror images of each other. A circle as an infinite number of lines of symmetry. Also a circle has an infinite number of points, not just 4. We don't know what you are talking about there. Also, what does it mean for a circle to "dot up"? That phrase makes no sense. Can you please explain exactly what you mean? |
| Sep14-12, 10:18 AM | #9 |
Yes you are correct that you draw a line through an object. I'm saying there are two lines. Horizontal and vertical. It makes sense to do this if you are making something. If symmetry happens at the number 10 is this not finite. What I'm trying to explain or figure out is the number sequence 0 through 10 round or not. I understand it's square if you go from 1 to 10 but I explained that you need to flip it from the number 5 to 10 to 5 to make it round. |
| Sep14-12, 10:20 AM | #10 |
Look, nobody here is trying to give you a hard time, it's just that either you seem to be talking nonsense or we just can't figure out what you ARE talking about. Are you seriously suggesting that pi is not the ratio of circumference/diameter ? That WOULD be nonsense, so what ARE you suggesting? |
| Sep14-12, 10:27 AM | #11 |
I'm not suggesting that pi isn't C/d. I guess what I'm saying is isn't the circumference 10. Diameter 2.5 because you can investigate the circle using 4 points or two symmetric lines. Maybe I got the diameter wrong trying to explain this. |
| Sep14-12, 10:37 AM | #12 |
Recognitions:
| Sep14-12, 10:40 AM | #13 |
The circumference is the distance around the circle. If you start at one point on the circle. Call it 0, and go half way around the circle, you will be at a point call it 5. Then a diameter of that circle passes through the point you call 0 and the point you call 5. However the length of that diameter is not 5, unless the circumference is is exactly 5*pi. It seems to me you are trying to map the points on the interval [0,10] onto a circle. Is this correct? |
| Sep14-12, 10:44 AM | #14 |
You start by talking about a circle and then immediately say, "one would need to see the symmetry of 0 to 10 and more correctly 0 to 5 and from this point 10 to 5 in a line."
There are NO numbers automatically associated with a circle so this makes no sense at all. If you are thinking of some way of assigning numbers to a circle, or points on a circle, you will have to tell us what that circle is. |
| Sep14-12, 10:45 AM | #15 |
| Sep14-12, 10:48 AM | #16 |
| Sep14-12, 10:57 AM | #17 |
And you really must forgive me, for I am too dumb to understand. So please, let us try and understand each other. You say that a circle is perfectly symmetrical. I can agree with this, for any line that I can draw through the center of the circle cuts the circle into two identical pieces. I cannot, however agree to your statement that 0 through 10 behave in perfect symmetry as well. And for this I apologize. But please if you will, try and answer my questions so that I may learn. First, I do not know which numbers between 0 and 10 you refer to. Are you talking about just the whole numbers between 0 and 10? Such as 0, 1, 2, ... Or are you talking about all the numbers, rational and irrational alike? Secondly, as I cannot draw a line through numbers, I fail to see symmetry in the numbers 0 through 10. Can you please tell me in what way those numbers are symmetric? |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Importance of the number 5
| Would someone tell me about the importance of number theory? | Linear & Abstract Algebra | 8 | ||
| importance to me as a pure maths major? | Academic Guidance | 6 | ||
| importance of words vs importance of talent | General Discussion | 5 | ||
| Importance of zero | Linear & Abstract Algebra | 112 | ||
| Prime Number Importance??Help Please | Introductory Physics Homework | 5 | ||
