New Reply
Phases of Acetone and Diphenyl at room temp
Share Thread Thread Tools
Sep16-12, 05:46 PM   #1
I was reviewing a chart of Physical properties of pure substances (20 °C)
Acetone has a melting point of -95°C and boiling point of 56°C so you'd assume it's solid (but obvioulsy it's liquid). In addition, Diphenyl has a melting point of 70°C and boiling point of 255°C so you'd assume it's liquid (but it's solid).
What characteristics am I overlooking?
PhysOrg.com
PhysOrg
chemistry news on PhysOrg.com
>> Detecting mirror molecules: New technique reliably tells left-handed from right-handed variant of a compound
>> Chemists devise inexpensive, accurate way to detect prostate cancer
>> Overcoming resistance to anti-cancer drugs by targeting cell 'powerhouses'
Sep16-12, 06:35 PM   #2
Acetone melts at -95 degrees. Room temperature is 20 degrees. Why would this be a solid?
Sep16-12, 07:19 PM   #3
20°C is is greater than -95°C (melting ) so acetone would not have melted and is less than 56°C (boiling) so acetone would not have evaporated; I'm assuming the normal phase of acetone is liquid and you don't merely assume because something hasn't melted or boiled that it is solid? Is my presumption correct?
I honestly don't see what I'm missing.
Sep16-12, 09:00 PM   #4
20°C is more than -95°C, so the acetone will melt. See, water has melting point of 0°C, but you "drink" water, don't you? According to your argument, we must be eating ice.
Acetone was melted long ago (-95°C is not the temperature to come across easily), so we see it in its melted, liquid form. Just heat it past its boiling point, it will convert into vapour form.
Sep16-12, 09:20 PM   #5
Quote by biochem850 View Post
melting is the transition from solid to liquid.
-95 is when solid acetone transforms to liquid acetone. you then raise the temperature to 20 degrees, which is below 56.
New Reply
Thread Tools
Similar Threads for: Phases of Acetone and Diphenyl at room temp
Thread Forum Replies
Can my CPU temperature be less than room temp? Classical Physics 15
is there a liquid which is attracted by magnet at room temp. Materials & Chemical Engineering 5
heater causes room temp to rise Introductory Physics Homework 1
Room Temp Superconductivity Atomic, Solid State, Comp. Physics 15
Mass of air leaving a room with temp raised. Introductory Physics Homework 1
