Electric field due to two charged particles problem (includes solution)
The problem involves calculating the electric field intensity due to two point charges of equal magnitude but opposite signs, positioned along the x-axis. The specific tasks include determining the field intensity at a given point and approximating the field intensity while assessing the error in the approximation.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants discuss the calculation of electric fields from each charge and the implications of approximating the field due to one charge while ignoring the other. Questions arise regarding the accuracy of values obtained and the interpretation of the percent error formula.
Participants are actively engaging in clarifying their calculations and assumptions. Some have provided alternative formulations for the percent error and are checking each other's work for accuracy. There is an ongoing exploration of the directionality of electric fields produced by the charges.
Participants are working within the constraints of homework guidelines, focusing on understanding the underlying physics without providing direct solutions. There is a noted emphasis on ensuring the correct application of formulas and concepts related to electric fields.
s3a
Problem:
Two point charges of magnitude 0.1 μC and opposite signs are placed in a vacuum on the x-axis at positions -/+ 1, respectively.
(a) Calculate the field intensity at the point (0, 1).
(b) Approximate the value of intensity at a point 10 cm away from one charge by ignoring the effect of the other charge and determine the percentage of error due to such an approximation.
Solution:
(a) As in Fig. 1-8 (I drew it and attached it as TheFigure.jpg), the y components of the fields produced by each point charge cancel each other and their x components add, resulting in E = Qd/(4πϵr^3) a_x . With Q = 0.1 μC, d = 2 m, and r = sqrt(2) m, we find E = 636.4 a_x V/m.
(b) Each point charge dominates the field in its 10-cm vicinity, resulting in E ≈ +/- 180 a_r kV/m, were a_r is the radial unit vector with that charge as the center. The field is directed outward at x = -1 and inward at x = 1. The most error occurs when the test point is at (+/- 0.9, 0), with a relative percentage error of 100 × 1/(1 + 19^2) = 0.275%.
E = Qd/(4πϵr^3) a
I get how to do part (a) but I'm stuck at part (b). I tried computing the electric field (affecting the positive test charge) at the point (0.9, 0) solely from the Q charge and then solely from the -Q charge and then taking the ratio of the values as follows:
E_close = 1797548.488 V/m (radius of 0.1 m)
E_far = 2465.77296 V/m (radius of 0.9 m)
(2465.77296 V/m)/(1797548.488 V/m)(100%) = 0.1372%
and, I don't know if it's a coincidence or not but, I noticed doubling the previous value yields 0.274% (and the correct answer, according to the book, is 0.275%.
Could someone please shed some light on this?
Any input would be greatly appreciated!
Hi, s3a.
I'm not sure what the phrase "affecting the positive charge" means here. You want the field at the point (.9 m, 0)
I don't get these values for the field at (.9 m, 0) from the two charges. For the closer charge, r = 0.1 m as you say. But I get a different value for E_close. For E_far, r does not equal 0.9 m.
Percent error = 100*(approximate value - true value)/(true value)
The approximate value is the field due to the closer charge alone. The true value is the field due to both charges.
Hello TSny!
For the values I gave in my last post, I think I was using a wrong formula.
For the second comment you made, what I said was "affecting the positive TEST charge" which is a way to figure out the strength and direction of an electric field caused by some hypothetical and arbitrary particle with a positive charge.
As for the "Percent error = (100%)*(approximate value - true value)/(true value)" equation, I get 0.27% (with a periodic 7 – in other words, infinite 7s) instead of 0.275%. Just to make sure this is not another fluke, could you tell me if the work below is correct or not please?:
E_true = 1/(4πϵ) * (Q/0.1^2 – Q/1.9^2)
E_approx = 1/(4πϵ) * (Q/0.1^2)
Percent error = {1/(4πϵ) * (Q/0.1^2) - [1/(4πϵ) * (Q/0.1^2 – Q/1.9^2)]}/{1/(4πϵ) * (Q/0.1^2 – Q/1.9^2)}*{100%}
Percent error = {1/(4πϵ) * Q/1.9^2}/{1/(4πϵ) * (Q/0.1^2 – Q/1.9^2)}*{100%}
Percent error = {1/(4πϵ) * 1/1.9^2}/{1/(4πϵ) * (1/0.1^2 – 1/1.9^2)}*{100%}
Percent error = {1/1.9^2}/{1/0.1^2 – 1/1.9^2}*{100%}
Percent error = [0.0027 (with periodic 7)] * [100%]
Percent error = 0.27 (with periodic 7)
I see now. Sorry for overlooking the word "test".
Think about whether that negative sign is correct. Do the fields of the individual charges have the same direction or opposite direction at the point (.9, 0)? Otherwise, your work looks very good to me.
It's alright. :)
I see my mistake. The positive test charge is in the middle of a positive charge (on the left side) as well as a negative charge (on the right side) so both "encourage" the positive test charge to move towards the right side (which is the positive x-axis in the way people typically define the axes).
So, I'm now getting:
Percent error = |{-1/1.9^2}/{1/0.1^2 + 1/1.9^2}*{100%}|
Percent error = |-0.276243093|
Percent error = 0.276243093
which is exactly the book's answer (I checked and the 0.275% it gives at the end is rounded).
Also, I'm assuming the percent error equation is an absolute value function because, otherwise, I would get a negative answer doing this.
Please correct me if I said anything else that is wrong in this post (however minor it may be).
And, lastly, thank you for your help!
Good work! :smile:
  • · Replies 26 ·
  • · Replies 16 ·
