Projectile motion: Finding flight distance with air resistance
The discussion focuses on calculating the flight distance of a ball shot from a slingshot, considering air resistance. The ball, with a mass of 9N, is launched at a 60° angle from a height of 1m, using a slingshot with an elasticity of k = 700N/m. The drag force is calculated using the formula D = (C*P*(U^2)*A)/2, where C = 1, P = 1.2, U = 13.94, and A = 0.03142. The initial calculations yield a time of flight of 5.5 seconds and a distance of 17.4m without air resistance, while the drag is determined to be 3.66 kg/s, complicating the numerical solution for the actual distance traveled.
  • Understanding of projectile motion principles
  • Familiarity with Newton's laws of motion (F = ma)
  • Knowledge of energy conservation in mechanics (E = 0.5mv^2)
  • Basic grasp of drag force calculations in physics
  • Research numerical methods for solving 2D projectile motion with air resistance
  • Learn about the integration techniques used in physics simulations
  • Explore advanced drag force models for varying conditions
  • Study the effects of launch angle on projectile distance in the presence of air resistance
Students studying physics, particularly those focused on mechanics and projectile motion, as well as educators looking for practical examples of air resistance in real-world applications.
proctortom
A ball of mass 9N is shot from a slingshot at an angle of 60° from the ground. The slingshot is sitting 1m above the ground. The elasticity of the slingshot is k = 700N/m. Take gravity = 10m/s^2
Air resistance must be taken into account also. Use the formula D = ( C*P*(U^2)*A )/2
D = Drag
C = 1
P = 1.2
U = 13.94
A = 0.03142
How far (in the x direction) has the ball traveled when it hits the ground??
F = ma
E = 0.5mv^2
d = vt
d = vt + 0.5at^2
D = ( C*P*(U^2)*A )/2 (D = Drag)
The following calculations have already been found:
Initial force in Ball = 350N
Initial Energy in Ball = 87.5J
Time of flight without air resistance = 5.5sec
X-distance traveled without air resistance = 17.4m
Drag = 3.66 kg/s
I don't know how to apply the air resistance (drag) formula/calculation to what I have found.
This is quite hard as a problem. A 1D problem with quadratic drag could be solved analytically, but in 2D and higher, as far as I know, it can only be solved numerically.
  • · Replies 21 ·
