New Reply
Blackbody Heat Shields/Metal Sheets
Share Thread
Sep21-12, 03:28 AM   #1
A “blackbody heat shield” is used to reduce radiant heat loss in situations where standard low conductivity insulation (i.e. normal insulation) cannot be used. The shield is constructed using a set of parallel metal sheets, each with emissivity 1.0.
Explain how/why this “heat shield” works and determine how many sheets of metal are
required to reduce the heat loss to less than 20% of the unshielded value. (Hint: think
about the radiation absorbed by each sheet and how this energy will be re-radiated.)
Diagram:
I really need help with this xD I don't even know where to begin.
PhysOrg.com physics news on PhysOrg.com
>> Kenneth Wilson, Nobel winner for physics, dies
>> Two collider research teams find evidence of new particle Zc(3900)
>> Scientists make first direct images of topological insulator's edge currents
Sep21-12, 07:36 AM   #2
mfb
Mentor
Here are some ideas:
- assume that the whole problem is 1-dimensional
- begin with 1 heat shield: Where does it receive/emit radiation?
- assuming that the environment has a temperature of ~0, calculate the temperature of that heat shield in equilibrium
Sep21-12, 09:33 AM   #3
ummmm I still don't get it xD
do I use the equation:
Q = mC deltaT?
Sep21-12, 09:46 AM   #4
mfb
Mentor
No, that looks like regular conduction.
##P_{emitted}=\sigma A T^4## (Stefan-Boltzmann)
New Reply
Tags
heat shield, radiant, thermal
Similar discussions for: Blackbody Heat Shields/Metal Sheets
Thread Forum Replies
Magnets sliding down metal sheets (slower then non metals) Advanced Physics Homework 2
Heat Transfer, Blackbody Radiation Introductory Physics Homework 1
Metal heat General Physics 10
Heat shields? Introductory Physics Homework 2
Ablative Heat Shields Mechanical Engineering 3
