Another try at a difficult proof
  • Thread starter Thread starter sebasalekhine7
    Proof
The discussion revolves around a mathematical expression involving Riemann sums and series expansions, specifically examining the relationship between the expression \(\frac{x^n}{\sum_{i=1}^n x^{n-i}}\) and the form \(\frac{(x-1)x^n}{x^n-1}\). Participants express confusion and explore various methods to simplify or transform the sums involved.
  • Exploratory, Mathematical reasoning, Problem interpretation
  • Participants suggest defining new variables for summation and transforming the sums. Some express difficulty in understanding these transformations, while others propose multiplying the numerator and denominator by \(x-1\) to simplify the expression. There are also discussions about using known formulas for geometric series to derive results.
The discussion is active, with multiple participants offering different approaches and clarifications. Some guidance has been provided on transforming sums and simplifying expressions, but there is no explicit consensus on a single method or solution.
Participants are working within the constraints of a homework problem, which may limit the information available and the methods they can use. There is a recurring theme of questioning assumptions and exploring various interpretations of the problem.
sebasalekhine7
I found something very strange working with Riemann sums and expansion series.
Can anyone tell me why
[tex]\frac{x^n}{\sum_{i=1}^n x^{n-i}}=\frac{(x-1)x^n}{x^n-1}[/tex]
Excuse the profanity, but I thought in the beginning this was a disgusting joke! :smile: :confused:
Define a new variable of summation
[tex]j=:n-i[/tex]
Transform the sum [itex]\sum_{i=1}^{n} x^{n-i}[/itex] into a sum over "j" and the result will come out immediately.
Daniel.
P.S.What profanity?:confused:
Sorry, but I don't quite understand how to do what you just wrote.
The way I did, just multiply the numerator and denominator by x-1. So in the denominator you get 2 summations (one minus the other). Simplify the denominator.
It doesn't make any sense to me.
[tex]j=:n-i[/tex] (1)
[tex]i=1 \Rightarrow j=n-1[/tex] (2)
[tex]i=n \Rightarrow j=0[/tex] (3)
The new sum (over "j") becomes
[tex]\sum_{j=n-1}^{j=0} x^{j}=\sum_{j=0}^{j=n-1} x^{j}=\frac{x^{n}-1}{x-1}[/tex] (4)
Now plug it in the initial expression and u'll find the desired result...
Daniel.
If you multiply the denominator through by x-1 you get:
[tex]\sum_{i=1}^{n} x^{n-i+1} - \sum_{i=1}^{n}x^{n-i}[/tex]
You can simplify the above (try to make the two sums look the same) and get [tex]x^n-1[/tex]
How do you make that simplification...?
Daniel.
Daniel.
Similar to your method:
[tex]\sum_{i=1}^{n} x^{n-i+1} - \sum_{i=1}^{n}x^{n-i} =[/tex]
[tex]\sum_{i=1}^{n} x^{n-(i-1)} - \sum_{i=1}^{n}x^{n-i}=[/tex]
For the first sum, let j=i-1
[tex]\sum_{j=0}^{n-1} x^{n-j} - \sum_{i=1}^{n}x^{n-i} =[/tex]
[tex](x^{n-0} + \sum_{j=1}^{n-1} x^{n-j}) - (\sum_{i=1}^{n-1}x^{n-i} + x^{n-n}) =[/tex]
I take out the first term from the first sum and last term from the second sum.
The two sums that are left cancel each other out.
[tex]x^n-1[/tex]
Wow,that's so simple!*admirative*...Gosh,why didn't i think of that...?*envy*
Daniel.
P.S.We should let the OP decide which solution he likes best.
I think they are both equally creative, well, thanks a lot for your help.
Daniel.
:smile: well, yours is the faster solution.
Why can't one just use the sum for Geometric series ?
The denominator is [tex]x^{n-1} + x^{n-2} + ... + x^0 = \frac{x^n - 1}{x - 1}[/tex]
using the well worn sum for GPs, and the answer immediately follows.
Indeed, you can just cancel the [itex]x^n[/itex] on both sides. Invert to get:
[tex]\frac{x^n-1}{x-1}=\sum_{i=1}^n x^{n-i}}[/tex]
A well known fact.
PS: [itex]\sum_{i=1}^n x^{n-i}=\sum_{i=0}^{n-1} x^{i}[/itex]
  • · Replies 21 ·
  • · Replies 23 ·
