| New Reply |
Got the answer, not convinced possible in reality? |
Share Thread | Thread Tools |
| Sep25-12, 06:24 AM | #1 |
Inertial frame S' moves at a speed of 0.6c with respect to frame S. Further, x = x' = 0 at t = t' = 0. Two events are recorded. In frame S, event 1 occurs at the origin at t = 0 and event 2 occurs on the x axis at x = 3000m at t = 4*10-6 s. According to observer S', what is the time of (a) event 1 and (b) event 2? (c) Do the two observers see the two events in the same sequence or the reverse sequence? 2. Relevant equations Standard Lorentz Transformation Equations. 3. The attempt at a solution x1 = 0, x2 = 3000m, t1 = 0, t2 = 4*10-6 s x1' = 0, x2' = 2850m, t1' = 0, t2' = -2.5*10-6s Based on the question, x2' is some distance away and event 1 occurs at t = 0 in frame S'. 1) It requires some time for light to reach event 2 in S' 2) Event 1 ALREADY occurs at t = 0 Then shouldn't event 1 occur first regardless of whatever speed you are travelling? How does the concept of 'negative' time come into play here? I'm finding this very, very strange.. |
| Sep25-12, 07:32 AM | #2 |
Note also, that if the observers are at the origins of S and S', the observer in S' will still see e2 after e1. This is because e2, even if occurring earlier than e1 in S', is away from the observer, and the signal from that event still needs to reach the origin of S'; and that will take more time than is left before e1. The observer in S' will infer, based on his knowledge of the distance to e2, that it must have occurred 2.5 microseconds before e1. If the observers are halfway between e1 and e2 in their respective frames, then they will see the events exactly how they will think they happened, i.e., e1 before e2 in S, and e2 before e1 in S'. |
| Sep25-12, 07:34 AM | #3 |
Mentor
(Realize that built into the Lorentz transformations is the interesting fact that simultaneity is relative. That's pretty strange.) |
| Sep25-12, 08:59 AM | #4 |
Got the answer, not convinced possible in reality?This is exactly what I mean. How is it that the observer sees e1 first, followed by e2 and still say that e2 occurred before e1? As e2 is farther away, the signal from e2 arrives later than the signal from e1. |
| Sep25-12, 09:09 AM | #5 |
So what? We just keep track of two different notions: when the light from the events reach the observer and when the events must've happened according to his clock. The observer can measure distance and figure out when the events must've happened.
| Sep25-12, 09:20 AM | #6 |
Mentor
(The Lorentz transformations deal with measurements after already accounting for light travel time.) |
| Sep25-12, 09:25 AM | #7 |
Unscientific,
This is counter intuitive so confusion is always the first step toward understanding. Start with the (intuitive) non-relativistic case. You see two events, flash here and now and another flash distant and later. But you measure the speed of light from the distant flash and triangulate the distance and figure that it happened at the same time as the first. I moving relative to you in a non-relativistic universe would see the same sort of thing, (as we pass at t=0) I would see the first flash then measuring a different speed of light (your measurement plus our relative motion) and a different duration to observing the 2nd flash, and I'd triangulate its position to get agreement with you on the simultaneity of events. Critical to my agreeing with you as I move is my seeing the light signal traveling at a different speed relative to me than you see relative to you. We see light traveling (in this non-relativistic universe) in the same way as baseball's travel. Understand the non-relativistic situation then ask the question, what does insisting that the speed of light is the same for all observers change? |
| Sep25-12, 10:03 AM | #8 |
| Sep26-12, 12:29 PM | #9 |
But i'm still perplexed by the concept of 'negative' time...Unless in the question where it states that event 1 occurs at t = 0, but it says NOTHING about event 2. The question says event 1 happens at t = 0. Does this set the restriction that event 2 has not happened yet?? (Meaning, even before reading the question event 2 might have already happened) |
| Sep26-12, 12:44 PM | #10 |
Just to check:
Suppose an event P happens at (x1,t1) according to frame S. Does this mean that the time that the event actually happened should be t1 - tL where tL = x1/c ? |
| Sep26-12, 01:22 PM | #11 |
Negative time has no particular meaning. Zero time is an arbitrary reference, so anything that happened before that arbitrary reference is negative. In general relativity, however, that becomes necessary, too, because "observer time" is no longer just a simple function of the observer's position. |
| Sep27-12, 05:12 AM | #12 |
| New Reply |
| Tags |
| relativity |
| Thread Tools | |
Similar Threads for: Got the answer, not convinced possible in reality?
| why I am not always convinced living in EU makes sense | Current Events | 17 | ||
| Guys help me out with this.Im not convinced with something | Introductory Physics Homework | 0 | ||
| Geometric Realizations...sorry, not convinced. | Set Theory, Logic, Probability, Statistics | 10 | ||
| What would it take you to be convinced God existed? | General Discussion | 222 | ||
