How Do You Calculate Resistor Values in a Digital to Analog Converter?
  • Thread starter Thread starter uhdam
    Analog Digital
The calculation of resistor values in a Digital to Analog Converter (DAC) circuit involves using weighted resistors (R, 2R, 3R, 4R) alongside a feedback resistor (Rf). It is crucial to select a base resistance value that balances output frequency and drive power. A resistance that is too large limits maximum output frequency due to stray capacitance, while a resistance that is too small increases power consumption. The optimal base resistance should be slightly below the threshold that would restrict desired output bandwidth.
  • Understanding of Digital to Analog Converter (DAC) principles
  • Knowledge of resistor configurations in electronic circuits
  • Familiarity with feedback mechanisms in analog systems
  • Basic electrical engineering concepts related to resistance and frequency
  • Research the calculation methods for weighted resistors in DAC circuits
  • Learn about the impact of stray capacitance on DAC performance
  • Explore feedback resistor configurations and their effects on output
  • Investigate techniques for optimizing resistor values for desired bandwidth
Electronics engineers, circuit designers, and students studying analog signal processing will benefit from this discussion on calculating resistor values in DAC applications.
uhdam
Hello Everyone,
In Digital to Analog conversion circuit we use the weighted resistors(i.e R,2R,3R,4R) and one feedback resistor(i.e Rf). Here my question is that how to calculate the those resistor values? If you know any formulas please provide me...
uhdam said:
Hello Everyone,
You don't want to use too large of a base resistance value, or you will limit your maximum output frequency too much (because of the stray capacitance in your DAC output layout).
You don't want to use too small of a base resistance, because that will take too much drive power.
The base resistance value that you choose should be just a bit smaller than what it takes to start limiting your output bandwidth lower than you want.
  • · Replies 29 ·
