Physics Experiment Question; Projectile Motion
The discussion revolves around deriving an equation for calculating the theoretical range of a projectile in motion. Participants are exploring the principles of projectile motion, including the effects of initial velocity and launch angle on the range.
  • Participants discuss the need to combine equations for horizontal and vertical motion to derive the range. Questions are raised about the definition of "range" and its dependence on launch angle and initial speed. There are attempts to clarify the relationship between time of flight and the range, as well as the components of initial velocity.
Some participants have provided guidance on breaking down the initial velocity into its components and suggested combining equations for both dimensions of motion. There is an ongoing exploration of how to derive the range and how to validate the theoretical results with experimental data.
There is a mention of the assumption that the range refers to the horizontal distance traveled, and participants are considering the implications of different launch angles on this distance. The discussion also highlights the need to account for the acceleration in the vertical direction while noting that horizontal motion does not experience acceleration.
rumaithya
Hello, I have a question that says' Derive an equation for calculating the theoretical range.
I did like half of it, I got
t = sqrt[ (2y) / a ]
from the kinematic equation ( X = X0 + V0 t + 1/2 a t^2 ). How would I find the theoretical range after this?
And how to prove that the theory is consistent with the experiment?
please help.
Range of what? A projectile with a certain initial speed? Note that the range--the horizontal distance traveled--will depend on the angle that the projectile is launched.
You'll need to combine equations for both horizontal and vertical motion.
If you combine the two equations for projectile motion
[tex]y = y_0 + v_it + .5at^2[/tex]
[tex]x = x_0 + v_it +.5at^2[/tex]
into one equation, the highest range would be the vertex of the parabola, which is half of the total time I believe. I would suggest solving for t, then divinding that by 2 to get the time when the highest point is reached, which is what I'm assuming the "range" means.
Two comments, Jameson:
(1) Only the vertical component of the motion is accelerated.
(2) "Range" generally means horizontal distance traveled. (If you shot the projectile straight up, it would fall straight down. Range = 0.)
But, yes, the highest point attained is the vertex of a parabola.
please help.
You'd need to break your theoretical initial velocity and angle of projection down into the initial X and Y components.
(R being initial velocity magnitude, O being initial angle)
Vox R x cosO
Voy R x sinO
Then, you'll also have to break down your equations for motion into X and Y, I'm going to assume by range you mean distance which is X-motion...
(Xo being initial X position -usually 0-; Vox being the x-component's initial velocity)
X X(t) = Xo + Voxt + 0.5at^2
(Remember that the acceleration for the x-component is ZERO!)
Now, since you have a theoretical Vox, you can plug it into the above eq.
*edit* You'd also have to do the same for the Y component, and derive that equation. Then set that equal to zero, because that will tell you the two time the projectile will cross the X-axis. Pick the positive time and substitute it into your position-time function for X.
I believe that the above is right as for range, now as for the experimental proving bit, that I can't help with.
