Analyzing a coordinate transformation
The discussion revolves around the analysis of a coordinate transformation in the context of classical mechanics, specifically focusing on symmetry laws and the implications for action and conservation laws. Participants explore the mathematical formulation of the transformation, its effects on the action, and the conditions under which certain quantities are conserved.
  • One participant presents a coordinate transformation and its implications for the variation in action, expressing confusion about specific terms in the equations.
  • Another participant clarifies that the transformation is a point transformation and discusses the relationship between the derivatives of the coordinates and the Lagrangian, referencing Noether's theorem regarding symmetries and conserved quantities.
  • A later reply indicates an understanding of the Euler-Lagrange equation's role in the derivation of the variation in action and attempts to connect this to conservation laws, particularly in the context of motion constrained to a circle.
  • Further discussion raises the condition that the Lagrangian must be independent of certain coordinates (like theta) for the corresponding momentum to be conserved, questioning the interpretation of coordinate system rotation versus particle motion.
Participants express varying degrees of understanding and interpretation of the mathematical formulations and their implications. There is no consensus on the interpretation of the conservation laws in relation to the coordinate transformation and the physical motion of particles.
Participants highlight the importance of ensuring that transformations leave the action invariant and discuss the implications of cyclic coordinates on conservation laws. Some assumptions about the independence of the Lagrangian from specific coordinates are noted but not fully resolved.
This discussion may be of interest to students and researchers in classical mechanics, particularly those exploring the connections between symmetries, transformations, and conservation laws in Lagrangian and Hamiltonian formulations.
mjordan2nd
In McCauley's book Classical Mchanics: Transformations, Flows, Integrable and Chaotic Dynamics we are analyzing a coordinate transformation in order to arrive at symmetry laws. A coordinate transformation is given by [itex]q_i(\alpha) = F_i(q_1,...,q_f, \alpha)[/itex]. Then, to the first order Mccauley states in equation 2.50 an infinitesimal shift in the coordinates can be given by
[tex] \delta q_i = \left[ \frac{\partial q_i(\alpha)}{\partial \alpha} \right]_{\alpha=0} \delta \alpha[/tex]
The variation in action is then given as
[tex]\delta A = \int_{t_1}^{t_2} \frac{dL_{\alpha}}{d \alpha} \delta \alpha dt = \int_{t_1}^{t_2} \left(\frac{\partial L_{\alpha}}{\partial q_i(\alpha)}{\partial q_i(\alpha)}{\partial \alpha} + \frac{\partial L_{\alpha}}{\partial \dot{q}_i(\alpha)} \frac{\partial \dot{q}_i(\alpha)}{\alpha} \right) \delta \alpha dt.[/tex]
I understand up to here. The book then states that we can deduce the following from the above:
[tex]\delta A = \left[ \left[ \frac{\partial L_{\alpha}}{\partial \dot{q}_i(\alpha)} \delta q_i \right]^{t_2}_{t_1} \right]_{\alpha=0} = \left[ p_i(\alpha) \left[\frac{\partial q_i(\alpha)}{\partial \alpha} \right]_{\alpha = 0} \delta \alpha \right]_{t_1}^{t_2} .[/tex]
I don't understand this line. For instance, shouldn't it be [itex]\delta \dot{q}_i[/itex] in the second expression? Or shouldn't the q be undotted? But then where does the second term from the above equation go? Again, any help would be appreciated.
Thanks.
According to the form of your transformation, i.e., a point transformation that is not explicitly time dependent (also [itex]\alpha[/itex] is not time dependent here, i.e., you have a global symmetry under consideration) you have
[tex]\frac{\partial \dot{q}_i}{\partial \alpha}=\frac{\mathrm{d}}{\mathrm{d} t} \frac{\partial q_i}{\partial \alpha}.[/tex]
Further, due to the equations of motion (Euler-Lagrange equations of the variational problem of Hamilton's principle) you have
[tex] \frac{\partial L}{\partial q_i} = \frac{\mathrm{d}}{\mathrm{d} t} \frac{\partial L}{\partial \dot{q}_i}.[/tex]
Thus, for the trajectory of the particle the integrand is a total time derivative and thus you have
[tex]\delta A=\delta \alpha \left [ \left (p_i \frac{\partial q_i}{\partial \alpha} \right )_{\alpha=0} \right]_{t=t_1}^{t=t_2}.[/tex]
As written in the book.
Further by assumption your infinitesimal transformation is a symmetry of the action, i.e., the actino doesn't change, and our derivation shows that along the trajectory of the particle the quantity
[tex]Q=\left (p_i \frac{\partial q_i}{\partial_ \alpha}\right )_{\alpha=0}[/tex]
is constant in time, i.e., it is the conserved quantity of the symmetry under consideration, which is one of Noether's theorem.
You can also show the opposite: I.e., if you have a conserved quantity there must be a symmetry of the action, generated by the conserved quantity. In other words each conserved quantity implies a one-parameter symmetry group of the action. This is another of Noether's theorems.
The latter theorem becomes much more elegant in the Hamiltonian formulation of Hamilton's principle, where you have everything in terms of the Lie algebra on the phase-space functions with the Poisson bracket as the Lie product. Then the infinitesimal symetry transformations form a subalgebra, and the finite symmetry transformations are given by the flow of the Lie derivatives of the phase-space variables with respect to the generator of the symmetry, which then turns out to be the corresponding conserved quantity.
I think I understand now. The fact I think I overlooked is that everything we are working with must satisfy the Euler-Lagrange equation since we are dealing with real, physical particles. So essentially the integral representing the variation in action can be rewritten as
[tex] \int_{t_1}^{t_2} \left( \frac{d}{dt} \left[ \frac{\partial L_{\alpha}}{\partial \dot{q}_i(\alpha)} \right] \frac{\partial q_i(\alpha)}{\partial \alpha} + \frac{\partial L_{\alpha}}{\partial \dot{q}_i(\alpha)} \frac{\partial \dot{q}_i(\alpha)}{\partial \alpha} \right) \delta \alpha dt = \int_{t_1}^{t_2} \frac{d}{dt} \left[ \frac{\partial L_{\alpha}}{\partial \dot{q}_i(\alpha)} \frac{\partial q_i}{\partial \alpha} \right] \delta \alpha dt = \left[ \frac{\partial L_{\alpha}}{\partial \dot{q}_i(\alpha)} \frac{\partial q_i}{\partial \alpha} \delta \alpha \right]_{t_1}^{t_2}.[/tex]
Then based on the equation given above for an infinitesimal shift in the coordinates this can all be rewritten as
[tex] \left[\left(\frac{\partial L_{\alpha}}{\partial \dot{q}_i(\alpha)} \delta q_i \right)_{\alpha=0} \right]_{t_1}^{t_2},[/tex]
and by definition of the canonical momentum you get, as you stated
[tex] \delta A=\delta \alpha \left [ \left (p_i \frac{\partial q_i}{\partial \alpha} \right )_{\alpha=0} \right]_{t=t_1}^{t=t_2}.[/tex]
Then if the action variation is 0, Q will be conserved across the transformation, correct? I don't fully understand how this leads to a conservation law in general, though. For instance, let's say we are restricted to motion on a circle of radius r. Then, we can say that [itex]\alpha = \theta[/itex]. So a change in alpha would be some small rotation of the coordinate system. As we rotate the coordinate system, this means that the canonical (angular) momentum would be conserved. But how does this translate into a conservation law when the particle is moving along the circle itself. Or have I misinterpreted the math?
Of course, you have to make sure that your transformation really leaves the action invariant. Thus, in your example, the rotation is only a symmetry, if the Lagrangian doesn't depend on [itex]\theta[/itex]. Then the canonical momentum [itex]p_{\theta}[/itex] (which is an angular-momentum component along the axis of rotation, parametrized by [itex]\theta[/itex]). That's why generalized coordinates, on which the Lagrangian doesn't depend are called cyclic.
So assuming the Lagrangian is independent of theta should make the angular momentum a conserved quantity when the coordinate system is rotated. But can the rotation of the coordinate system be reinterpreted as the particle rotating rather than the coordinate system rotating? Is this interpretation what makes the angular momentum a constant when it is the particle moving rather than the coordinate system rotating?
  • · Replies 19 ·
  • · Replies 38 ·
  • · Replies 17 ·
