New Reply
Using Stress/Strain Curve to Find Yield Strength and Modulus of Elasticity
Share Thread Thread Tools
Oct6-12, 10:06 PM   #1
Hey guys,
I recently did a compression lab with different materials (wood and pvc pipe) and I have to plot the stress/strain curves given the data collected, as well as find yield strength (0.2% offset), ultimate compressive strength, and modulus of elasticity. I've already calculated stress and strain and plotted the data for one of them. I just wanted to make sure I was doing everything right. So:
Yield Strength @ 0.2% Offset: from what I understood, I take the slope of the curve (before it peaks) and draw a line with the same slope, but starting at 0.2 on the y axis instead of 0, and wherever it intersects with the original graph is my yield strength
Ultimate Compressive Strength: I'm not too sure about this, but I assume that the highest peak on the graph is the ultimate compressive strength, because it is the most stress it can endure before failing. Could someone confirm this/explain the theory if I'm wrong about this? And if I'm wrong, is there a way to calculate this?
Modulus of Elasticity: This is equal to E = (F)(L1)/(A)(L2) where:
F = the force applied to the material
A = the cross-section area through which the force was applied to the material
L2 = amount the length of the material changes when the force is applied
L1 = original length of the material (before the force was applied)
For Modulus of Elasticity,is L2 the final length that it changed when force was applied?
Sorry that these are kinda dumb questions, I was out of the province when the material was covered in my lectures. Thanks for looking!
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Heat-related deaths in Manhattan projected to rise
>> Dire outlook despite global warming 'pause': study
>> Sea level influenced tropical climate during the last ice age
Oct7-12, 01:31 AM   #2
Recognitions:
Homework Helper Homework Help
The modulus of elasticity is defined as the ratio of the stress to strain, so from your stress-strain curve, the gradient of the linear region would give you the value for E of the material.
Oct7-12, 01:31 AM   #3
Recognitions:
Oct7-12, 01:22 PM   #4
So then...the slope of the linear portion of the curve?
Oct7-12, 01:42 PM   #5
Recognitions:
Quote by tesla93 View Post
Yes.
Oct7-12, 08:19 PM   #6
Awesome, thanks! :)
Oct7-12, 09:28 PM   #7
Hey guys,
The 0.2% offset is done by taking the slope of the linear component of the plot and offsetting it 0.2% on the x-axis. See here for pictorial description: http://en.wikipedia.org/w/index.php?...eld.svg&page=1. You can then read the stress value at the intersection point.
Cheers!
New Reply
Thread Tools
Similar Threads for: Using Stress/Strain Curve to Find Yield Strength and Modulus of Elasticity
Thread Forum Replies
Effect of Strain Hardening on Yield Strength Engineering, Comp Sci, & Technology Homework 0
elasticity,stress, and strain questions Introductory Physics Homework 2
elasticity,stress, and strain questions Engineering, Comp Sci, & Technology Homework 1
load, elasticity, strain, strength Engineering, Comp Sci, & Technology Homework 1
Finding yield stress with only modulus of elasticity and Poisson's ratio? Engineering, Comp Sci, & Technology Homework 3
