Consecutive integers such that the prime divisors of each is less or equal to 3
  • Context: Graduate
  • Thread starter Thread starter Wiz14
    Integers Prime
The discussion revolves around finding distinct positive integer triples (x, y, z) that are in arithmetic progression and have their largest prime factor less than or equal to 3. Participants explore various solutions, restrictions, and methods for proving the completeness of their findings.
  • One participant proposes the triples 22k + 1, 22k + 1 + 22k, and 22k + 2 as potential solutions, in addition to the known solutions (1,2,3), (2,3,4), and (6,9,12).
  • Another participant claims that the complete list of primitive solutions is (1,2,3), (2,3,4), and (2,9,16), suggesting that other solutions can be excluded using modular arithmetic.
  • A later reply questions how to prove the completeness of the proposed solutions and challenges the assertion that they are the only solutions, citing additional solutions such as (18, 27, 36) that arise from multiplying primitive solutions by powers of 2 and 3.
  • One participant clarifies that a primitive solution is defined as a triple where the integers have no common factors and discusses the necessity of case-by-case analysis to exclude other possibilities.
  • Another participant humorously suggests (1,1,1) as a potential solution, questioning its validity as an arithmetic progression while acknowledging the requirement for distinct numbers.
Participants express differing views on the completeness of the proposed solutions, with some asserting that additional solutions exist while others maintain that their lists are exhaustive. The discussion remains unresolved regarding the full set of valid triples.
Participants mention the need for case-by-case analysis and modular considerations to exclude certain solutions, indicating that the reasoning may depend on specific assumptions and definitions that are not fully articulated.
Wiz14
For each integer n > 1, let p(n) denote the largest prime factor of n. Determine all
triples (x; y; z) of distinct positive integers satisfying
 x; y; z are in arithmetic progression,
 p(xyz) <= 3.
So far I have come up with 22k + 1, 22k + 1 + 22k, and 22k + 2 other than the solutions 1,2,3, or 2,3,4 or 6,9,12. Is this sufficient?
If we restrict the discussion to the primitive solutions, the complete list will be (1,2,3), (2,3,4) and (2,9,16). You can exclude the rest by simple considerations modulo 3 and 8.
Thank you for your answer, but can you be more specific? How can we prove that your solutions and my solutions are the only solutions?
Your solutions are not the only solutions if we allow multiplying each primitive solutions by 3^a * 2^b as you did as you left out solutions such as 18, 27, 36.
but how to exclude the rest by considerations mod 3 and 8? thank you.
By a primitive solution, I mean a triple (a,b,c), where a, b and c have no common factor. In that sense, the list (1,2,3), (2,3,4), (2,9,16) is complete.
To exclude the rest, you need to do some case by case analysis. One useful initial observation is that exactly one of the numbers is divisible by 3, as alternatives quickly lead to contradictions. Then the case (odd, odd, odd) should be trivial to deal with. Looking at (odd, even, odd), this has to be of the form (1, 2m, 3n) giving the equation 2m+1=3n+1. Here the RHS[itex]\equiv[/itex]2 or 4 (mod 8), so m<3, giving the solution (1,2,3). The case (even, odd, even) has to be of the form (2t,3n,2m). For m<3, we have (2,3,4). For m≥3, the last number is [itex]\equiv[/itex] 0 mod 8, the middle is [itex]\equiv[/itex]1 or 3 mod 8, so the first must be [itex]\equiv[/itex]2 or 6 mod 8, implying t=1, and n even. The resulting equation is 3n=2m-1+1 or (3c-1)(3c+1)=2m-1 where c=n/2 can only take the value 1, and we get (2,9,16), and we are done.
Other soluion is (1,1,1) ? Is that an arithmetic progression? See http://en.wikipedia.org/wiki/Arithmetic_progression Never mind the problem asked for distinct numbers
  • · Replies 17 ·
  • · Replies 26 ·
