Struggling with finding the mass req'd when velocity is doubled
  • Thread starter Thread starter Harrison01
    Mass Velocity
The discussion revolves around a physics problem involving a mass-spring system. The original poster seeks to determine the mass required to achieve double the maximum velocity of a mass suspended from a spring, given specific parameters such as spring stiffness and initial displacement.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants explore the relationship between mass, angular frequency, and maximum velocity using equations related to harmonic motion. Some question the assumptions behind energy conservation and the implications of doubling velocity on mass.
There are various approaches being discussed, with some participants providing calculations and others questioning the clarity of notation and the reasoning behind the relationships. Guidance has been offered regarding the symbolic representation of variables, but no consensus has been reached on the final interpretation or calculations.
Participants note the importance of maintaining energy consistency in the system and question whether the relationship between mass and velocity can be simplified as suggested. There is an acknowledgment of the complexity involved in the problem, particularly regarding the assumptions made about energy transfer and mass adjustments.
Harrison01
Hey peeps, I'm really struggling with this one and I'm looking for a point in the right direction.
A mass of 0.3 kg is suspended from a spring of stiffness 200 N m¯¹. If the mass is displaced by 10 mm from its equilibrium position and released, for the resulting vibration,
(iv) the mass required to produce double the maximum velocity calculated in (ii) using the same spring and initial deflection.
Am i right in assuming that i need to use a transposition of the following formula to find mass,
f=1/2pi√ k/m
This is where i struggle as I am having a blonde moment and just can't seem to start this one.
so far i have,
frequency of 4.109
time of 0.243
velocity of 0.25819
accelecration of 6.666
New velocity of 0.51638 (2x.25819)
I'm no expert so please don't take my answer as law, but I worked it out going back from the original Vmax of 0.258ms-1
You need to find the mass that will give you double your original Vmax which will be 0.516ms-1
I used equations Vmax=Aω and ω=√(k/m)
Im sure someone could correct me if I'm wrong?
Your approach is correct. You could also try using conservation of energy.
So using the new Vmax
Vmax = Aω
0.516 = 0.01ω
ω = 0.516/0.01
ω = 51.6
ω = √(k/m)
51.6 = √(200/m)
m = 200/51.62
m = 0.075kg
Does that look correct?
That is correct, but you do not really have to get the numeric value of Vmax and ω. Vmax = Aω, and 2Vmax = Aω', so 2√(k/m) = √(k/m'), yielding m' = m/4 = 0.3/4 = 0.075.
Unfortunately I'm not quite as gifted so I have to go the long way round just so it makes sense. When you use " ' " what does that mean?
I used m' to denote the mass that has twice the max velocity, and ω' means the angular frequency corresponding to twice the max velocity.
Speaking of giftedness, that's not it, it just takes a little practice. You should always try to solve problems symbolically throughout, and plug the numbers only at the very end.
OK, I see.
I suppose only using numbers at the end reduces the chance for error througout the workings as well.
f=1/2pi√ k/m
so far i have,
frequency of 4.109
time of 0.243
velocity of 0.25819
Seems to me that you are doing the same amount of work on the spring, when displacing it form the equilibrium position, in each case. That should store the same amount of energy in the spring, which will be converted to maximum Kinetic energy when the mass passes through the equilibrium position.
That means the mass will have the same amount of kinetic energy each time, so mv2 is the same both times.
If the speed is to be doubled, the contribution of the v2 is up by a factor of 4, so it would seem the mass has to be reduced by a factor of 4 to compensate.
Perhaps it is not that simple?
  • · Replies 23 ·
47K
