Confusion with Electric Potential/Potential Energy
The discussion focuses on calculating the electric potential energy of a system with three fixed charges: 20.0 nC, -20.0 nC, and 10.0 nC, positioned at (0, 4.00 cm), (0, -4.00 cm), and the origin, respectively. To find the total potential energy, the formula U = k(q1*q2)/r is utilized, where k is Coulomb's constant (8.99 x 10^9 Nm²/C²). The correct approach involves calculating the potential energy for each pair of charges and summing them, leading to a final answer of -4.5e-5 J. The distinction between electric potential and potential energy is clarified, emphasizing that electric potential is energy per unit charge.
  • Understanding of Coulomb's Law and Coulomb's constant (k = 8.99 x 10^9 Nm²/C²)
  • Familiarity with electric potential (V) and electric potential energy (U)
  • Basic knowledge of charge interactions and distances in electrostatics
  • Ability to perform calculations involving nanocoulombs (nC) and centimeters (cm)
  • Study the concept of electric potential energy in multi-charge systems
  • Learn about the relationship between electric potential and electric field
  • Explore advanced topics in electrostatics, such as potential energy in continuous charge distributions
  • Practice problems involving the calculation of electric potential and energy with varying charge configurations
Students in physics, electrical engineering professionals, and educators seeking to deepen their understanding of electrostatics and charge interactions.
sisigsarap
There is a problem I am finding quite confusing:
Two particles, with charges of 20.0 nC and -20.0nC, are placed at the points with coordinates (0,4.00cm) and (0,-4.00cm). A particle with charge 10.0 nC is lcoated at the origin. Find the electric potential energy of the configuration of the three fixed charges.
I am having difficulty understanding the last sentence. For electric potential energy I thought I would use V = 8.99*10^9(q/r) , where I would sum up each charge? For example:
V1 = 8.99*10^9(20nC/4cm) V2 = 8.99*10^9(-20nC/4cm) V3=8.99*10^9(10/0)
Then the Electric potential energy would be V1 + V2 + V3 = 0?
Or would I use U = 8.99*10^9(q1*q2)/(distance from q1 to q2)
and follow the same procedure?
I am very confused with the question and what the book refers to as potential energy and electrical potential??
Any help is appreciated!
Thanks!
Since the electric potential, V, is the potential energy per unit charge it is a scalar quantity that is a function of the separation and the charge. Since it is directionless, potentials can just be added together.
[tex]V = U/q = \int_\infty ^R \frac{kQ}{r^2}dr = \frac{kQ}{R} - 0[/tex]
[tex]U = Vq = \frac{kQq}{R}[/tex]
In order to find the total potential energy, take the potential energy of each pair of charges and add them up (be careful with the signs).
The answer, I think, is -4.5e-5 J.
AM
The confusion you are experiencing is understandable as electric potential and potential energy are closely related concepts. Electric potential is a measure of the electric potential energy per unit charge at a specific point in space. In other words, it is the amount of electric potential energy that would be experienced by a unit charge if placed at that point.
In this problem, you are asked to find the electric potential energy of the configuration of three fixed charges. This means you need to find the total amount of energy required to assemble the three charges in this specific arrangement.
To do this, you can use the equation U = k(q1*q2)/r, where k is the Coulomb's constant (8.99*10^9 Nm^2/C^2), q1 and q2 are the charges of the two particles and r is the distance between them. You would need to calculate the potential energy for each pair of charges (q1 and q2, q1 and q3, q2 and q3) and then add them together to get the total potential energy of the system.
Alternatively, you can also use the equation V = k(q/r), where V is the electric potential, k is the Coulomb's constant, q is the charge and r is the distance. In this case, you would need to calculate the electric potential at each point where a charge is located and then add them together to get the total potential energy of the system.
In summary, electric potential and potential energy are related but not the same. Electric potential is a measure of potential energy per unit charge, while potential energy is the total amount of energy required to assemble a system of charges in a specific arrangement. I hope this helps clarify your confusion.
14K
