Initial Velocity of Projectile Motion, given displacement and initial angle?
The discussion revolves around a projectile motion problem involving a grasshopper that jumps 1.00 meters at a 45.0° angle from rest. Participants are tasked with finding the initial speed and maximum height of the jump, using the provided equations of motion.
  • Participants discuss resolving the initial velocity into horizontal and vertical components and question the interpretation of the displacement given in meters. There are inquiries about the vertical component of velocity at the peak of the jump and how this relates to finding the initial speed.
The discussion is ongoing, with participants exploring various approaches to relate time, distance, and velocity. Some guidance has been offered regarding the relationship between the time to reach the peak and the total time of flight, but no consensus or resolution has been reached.
Participants are navigating initial confusion about the problem's parameters and the implications of the angle of projection. There is an emphasis on understanding the components of motion and the relationships between them, with no explicit consensus on the method to solve for the initial velocity.
allure
A grasshopper jumps 1.00 meters from rest, with an initial velocity at a 45.0° angle with respect to the horizontal. Find (a) the initial speed of the grasshopper and (b) the maximum height reached.
vx = v0xt = v0cos θ0
vy = v0 sin θ0 - gt
I was unsure what to do, so I resolved for the components, resulting in
v0x = v0 cos 45°
v0y = v0 sin 45°
I apologize for my cluelessness - this my first semester in physics (at all), and I am having trouble finding where to go about this problem. Thank you in advance.
is that 1.00 supposed to be in meters? Is the grasshopper jumping 1.00 meter forward across the ground?
also, when the grasshopper reaches the peak of its arc through the air, what is the magnitude of the *vertical component* of the velocity? (this is a question that is trying to push you in the right path, the first one is clearing up some confusion on what the problem is asking)
Yes, meters - sorry. I have edited the above.
The velocity of the peak of the arc would be 0. I tried to look for a way to use this to find the initial speed but I'm stuck, is there a way I can use this information to do that?
well so you can solve for the t it takes to get to that point
and so then if that's the amount of time it takes to get to the *peak*, how long does it take the grasshopper to go the full distance?
So far, I've solved using Vy sin θ0 - gt
to get
tmax = v0sin 45°/9.8
ttotal = 2(v0 sin 45°/9.8)
Without the initial velocity, I'm not sure how (if I can) to simplify any further, or solve for it..
45 degrees is right in the middle of completely horizontal and completely vertical. You might feel like the horizontal and vertical components should be the same, and indeed they are. cos45=sin45 Might as well take Vox and call it Voy
X = Voyt ,where X is the horizontal distance traveled.
Vyf = Voy -gt
However Vyf is right before hitting the ground... it must have equal magnitude but opposite direction of Voy so:
-Vyo = Voy -gt
So you have 2 equations, two unknowns and can solve.
so if you know that the time taken for the grasshopper to end its jump is ttotal = 2(v0 sin 45°/9.8)
and that it went 1 meter
and you know that
x = v0,xt = v0cos(θ)t
what could you do with that
