Is the net torque calculated correctly in both pictures?
  • Thread starter Thread starter davon806
    Torque
The discussion revolves around the calculation of net torque in two different scenarios involving a weight acting on an object about a pivot point. Participants are analyzing the expressions for torque derived from the weight's components and their respective distances from the pivot.
  • Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants explore the correctness of two expressions for net torque, questioning the assumptions made about the center of mass and the definitions of variables used in the calculations.
There is an ongoing examination of the torque expressions, with some participants providing insights into the implications of different assumptions. The discussion reflects a mix of agreement and differing interpretations regarding the definitions of variables and the resulting calculations.
Participants are grappling with the implications of resolving weight into components and the effects of the center of mass's position relative to the pivot. The discussion includes references to specific angles and distances, which may not be fully defined in the original problem statement.
davon806
Please see the attached,both picture shows the weight acts on the centre of mass.
In picture 1,the net torque acts on the object about the pivot is Wcosθx
In picture 2,I resolve the weight into two components.Wcosθ and Wsinθ,
the net torque about the pivot is Wcosθx - Wsinθy
Which one is correct?Thx
As mentioned above and the attached
How do you get the first expression?
It cannot be right: If the center of mass would be right above the pivot (=> 0 torque), you would get the same torque with that formula.
No,I assume that the centre of mass is at the left of the line of pivot.
Or let's think in this way,
the weight is the only force that causes the object to rotate about the pivot,
the perpendicular distance between the centre of mass and the pivot = xcos(theta) m
So the moment about the pivot = Wxcos(theta) Nm
But if we resolve weight into horizontal and vertical components,
clockwise resultant moment = Wsin(theta)y
anticlockwise resultant moment = Wcos(theta)x
So the resultant moment about pivot = Wcos(theta)x - Wsin(theta)y ?
I don't see how this assumption is used to get Wcos(θ)x.
No.
Why?
What is the formula of the resultant moment about the pivot?
push
Wait, you changed the definition of x there. That is possible (and gives the correct result), but then you cannot compare it to the other way to calculate it.
davon806 said:
push
That does not help, I cannot answer when I am not here anyway :p.
Sorry for my ugly drawings and thanks for your reply :)
But if picture 1 is correct,i.e.
Then picture 2 is incorrect,
anticlockwise moment=Wcosθx
clockwise moment=Wsinθy
As the object would rotate anticlockwisely,
Wcosθx > Wsinθy,so the net moment about the pivot = Wcosθx - Wsinθy?
Wcos(θ)x - Wsin(θ)y is right with your first definition of x and y, Wcos(θ)x is right with your second definition of x. As you can see, it is a bad idea to use two different definitions for the same variable at the same time.
Thank you very much.:)
I finally realize why I would make such a silly mistake.It's simply due to my ugly drawings.
  • · Replies 22 ·
10K
