Integrate improper integral with infinite discontenuities
The discussion revolves around evaluating an improper integral involving the function 7/(x-9)^2 over the interval [8, 10]. Participants are exploring the convergence or divergence of the integral due to the presence of a discontinuity at x = 9.
  • Participants discuss the need to split the integral at the point of discontinuity (x = 9) and consider the limits as they approach this point. There are attempts to clarify the correct notation and limits for the evaluation of the integral.
Some participants have provided guidance on how to properly set up the limits for the integral and have pointed out potential errors in the original poster's approach. There is an ongoing exploration of the correct method to handle the discontinuity.
Participants note that the integral diverges at the point where the denominator becomes zero, which is a critical aspect of the problem that needs to be addressed in the evaluation process.
alust92
Integrate the improper integral (use correct notation). State whether it's converging or diverging.
∫ 7/(x-9)^2 dx
b c
∫ f(x) dx= lim ∫ f(x) dx
a c → d a
b
lim ∫ 7(x-9)^2 dx
c → 10- 8
Let u= x-9
-du= dx
lim ∫ -u^2
c→10-
lim -2u^2
c→10-
lim -2(x-9)^2
c→10-
lim -2(10-9)^2-2(8-9)^2
c→10-
I know I must be doing something wrong because the answer is ∞, any ideas where I went wrong?
Mod note: Added [ code ] tags to preserve the OP's spacing.[/color]
∫ 7/(x-9)^2 dx
Code:
b                            c
a             c → d      a
Code:
                      b
        lim        ∫  7(x-9)^2 dx
       c → 10-   8
Let u= x-9
-du= dx
Code:
lim       ∫ -u^2
c→10-
lim -2u^2
c→10-
lim -2(x-9)^2
c→10-
c→10-
The problem is not at 10 - it's at 9, which is where the denominator becomes zero. You're going to have to split the interval [8, 10] into two parts, and then deal with each separately.
Ok, so here's what I've got.
9 10
∫ 7/(x-9)^2 dx + ∫ 7/(x-9)^2
8 9
9 9
∫ 7/(x-9)^2 dx = lim ∫ 7/(x-9)^2 dx
8 x→9 810 9
8 x→9 8
∫ 7/(x-9)^2 dx
Am I on the right track?
Code:
9                            10
8                           9
The above is correct.
alust92 said:
Code:
9                                    9
8                          x→9   8
The limit should be taken as b →9-, not as x →9. The upper limit of integration should be b.
What you have just below is just the repeat of the line above.
alust92 said:
Code:
10                                      9
8                            x→9    8
∫   7/(x-9)^2 dx
  • · Replies 105 ·
13K
