Understanding Circuit Questions: Current, Voltage, and Resistors Explained"
  • Thread starter Thread starter dayrinni
    Circuit
This discussion clarifies fundamental concepts in electrical circuits, specifically the relationship between current, voltage, and resistors. It establishes that current decreases when passing through a resistor, and while multiple resistors can be added to reduce current, it will never reach zero due to inherent resistance in the circuit. The relationship between voltage and current is defined, with voltage acting as the driving force for current flow. Current is measured in amperes (A) and voltage in volts (V), emphasizing the necessity of measuring both to understand circuit behavior.
  • Understanding of Ohm's Law (I = V/R)
  • Familiarity with electrical units: Amperes (A) and Volts (V)
  • Basic knowledge of circuit components, specifically resistors
  • Concept of potential difference in electrical circuits
  • Study the implications of Ohm's Law in complex circuits
  • Explore Kirchhoff's Circuit Laws for analyzing current and voltage in circuits
  • Learn about series and parallel resistor configurations and their effects on current
  • Investigate the concept of power in circuits using the formula P = IV
Electrical engineering students, hobbyists building circuits, and anyone seeking to deepen their understanding of circuit behavior and the interplay between current and voltage.
dayrinni
I have a couple questions about circuits.
Let's say I have a current flowing through the circuit and then it hits a resistor. The current will obviously go down while it is in the resistor but then does it stay reduced (By the strength of the resistor) for the duration of the circuit? So in theory you could put as many resistors as you needed to reduce the current to 0?
What is the relationship between the voltage on the battery and the current? A circuit with a voltage of 12 V will have that as a potential, and the current is what is actually going along the path. An example is having a highway and it's speed limit is 55 mph (It's voltage) and then the actual current is the car driving on the highway.
If that is right, I do not see why you do not measure current in terms of voltage, or a % of it along the path. Like at this point on the circuit the current is 5V (out of say 12V), not 5 A.
Thanks for any help.
The two basic equations for DC circuits that you should probably know:
[tex]I=\frac{V}{R}[/tex]
Current (Amps) is equal to the potential difference (Volts) divided by the resistance (Ohms).
and
[tex]P=IV[/tex]
The amount of power that something uses uses is equal to potential change multiplied by current.
For all but the simplest circuits, it's necessary to separate voltage from current in order to understand what's going on.
If you think of electricity as water, then voltage is the amount of pressure that the water is under, and current is the amount that is flowing. There are situations where there is low current and high potential difference like in fountain jets, and situations where there is massive current and little potential difference - like many rivers.
Great questions! Let's break them down one by one.
1. Does the current stay reduced while in a resistor and can you add as many resistors as needed to reduce the current to 0?
Yes, the current will stay reduced while in a resistor as long as the voltage remains constant. The resistor acts as an obstacle to the flow of current, causing it to decrease in strength. And yes, you can add multiple resistors in a circuit to further reduce the current, but it will never reach 0 as there will always be some resistance in the circuit.
2. What is the relationship between voltage and current?
Voltage is the potential energy difference between two points in a circuit, while current is the flow of electric charge. In simpler terms, voltage is the driving force that pushes the current through the circuit. The higher the voltage, the greater the potential for current to flow.
3. Why is current not measured in terms of voltage or a % of it along the path?
Current is measured in units of amperes (A) while voltage is measured in volts (V). They are two different quantities and cannot be interchanged. Current is the actual flow of electric charge, while voltage is the potential for that flow. It is important to measure both in order to understand the behavior of a circuit.
