Calorimetry Problem, calculating the specific heat of a unknown substance
The discussion centers on calculating the specific heat of an unknown metal using calorimetry principles. A 500.0-g chunk of the metal, initially at 100°C, is placed in 1.00 kg of water at 20.0°C, resulting in a final equilibrium temperature of 22.0°C. The heat gained by the water, calculated using the equation Q = mcΔT, equals the heat lost by the metal. The specific heat of the metal can be determined by equating the heat transfer equations for both substances.
  • Understanding of calorimetry principles
  • Familiarity with the equation Q = mcΔT
  • Knowledge of heat transfer concepts
  • Basic algebra for solving equations
  • Calculate specific heat using the equation Q(metal) = -Q(water)
  • Explore the concept of thermal equilibrium in calorimetry
  • Review examples of calorimetry problems involving phase changes
  • Study the properties of specific heat for various materials
Students studying thermodynamics, physics educators, and anyone interested in understanding calorimetry and heat transfer calculations.
klawlor419
A 500.0-g chunk of unknown metal, which has been in boiling water for several minutes, is quickly dropped into an insulating Styrofoam beaker containing 1.00 kg of water at room temperature (20.0 C). After waiting and stirring for 5.00 minutes, you observe that the water's temperature has reached a constant value of 22.0 C.
(a) Assuming that the styrofoam absorbs a negligibly small amount of heat and that no heat was lost to the surroundings, what is the specific heat of the metal?
parts (b) and (c) are separate easier questions, not relevant to (a).
Q=m c ΔT
Q(metal)=-Q(water)
Temp boiling water, 100 C, specific heat of water, 4190 J/kg-C
First I solved to find the heat absorbed by the water from the metal, in order to raise the temperature of the water 2 C. Secondly, with the assumptions made in the problem, I assume that the heat gained by the water is exactly that lost by the metal. Equating these terms and getting an equation for the specific heat has a problem, which is that I don't know ΔT for the metal. I am sure I am missing something simple, but I can't get around this term ΔT for the metal.
Assuming that the system has reached equilibrium (after all, the water temperature is said to have reached a constant temperature...), what temperature must the metal have?
Ah, thanks. That was simple
10K
