Finding magnetic field from two crossing wires
The problem involves two insulated wires crossing at a 30° angle in the x-y plane, each carrying a current of 3.0 A. The task is to find the magnetic field at two specific points located 4.0 cm from the intersection, equidistant from both wires.
  • Participants discuss the independence of the magnetic fields from each wire and how they combine. There is uncertainty about the impact of angles on the magnetic field calculations and the necessity of finding non-equivalent points. Some participants express confusion about the right-hand rule and how to determine the direction of the magnetic field.
Participants are actively exploring the problem, with some offering insights into the geometry of the situation and the need to consider multiple bisectors. There is recognition of the complexity involved in determining the direction of the magnetic field and how it relates to the current direction.
Participants note the challenge of understanding the problem's requirements, particularly regarding the angles formed by the crossing wires and the implications for calculating the magnetic field at the specified points.
Parad0x88
Two insulated wires in the x-y plane cross at a 30° angle but do not make electrical contact. Each wire carries 3.0 A current (the angle between current directions is 30°). Find magnetic field in two non-equivalent points located 4.0 cm from the intersection, in the x-y plane, at equal distances from both wires.
B = (μ0I)/(2r) For a straight wire
I'm not sure I understand the problem, or how to tackle it, could you guys help me out analyzing it? I understand the concept if I had only one wire, it would be simple, I know the value of μ0, of I (3.0 A) and of r (0.04 m)
From what I understood I did this drawing, now my issue is how do angles come into play?
The field from each wire is independent and can be easily calculated for the required positions.
The two fields add to give a resultant field.
(In your drawing, the two points are equivalent - you need to find another that is not equivalent)
Ooooh I see. So I could do:
Point 1) Directly perpendicular to the interesction (so at 90°) to the north
Point 2) In the south-east of the intersection, halfway between the south line and the second wire, so I'd have an angle of 60° from the horizontal, or 30° from the vertical.
I guess if I do that for point #2, I would simply do:
BX = (μ0I)/(2r) X Cos 60
BY = (μ0I)/(2r) X Sin 60
and then for the magnitude, √(BX2 + BY2)
Does that work?
4 cm from the intersection (draw a circle 4cm radius round the intersection)
Equidistant from both wires (draw a line that bisects the angle between the wires - there are two such lines)
Where the bisectors cross the circle you will find treasure.
If I followed you correctly, it would look like this?
But if I find B at both points, won't it give me the same answer?
R is the same in both cases, they are simply at opposite sides of the circle
There are TWO bisectors - you only have one.
Ok I don't follow anymore, I just don't understand the concept of the problem when I'm reading it. Could you help me figure out what I'm looking for?
Yes you do. You just have hit a blind-spot. It's staring you in the face.
When two lines cross they make two angles, not just one: α and 180-α. You can draw a bisector through α and another through 180-α. Look again at your drawing.
Ok well this part I understood (I hope), I redrew my figure... It's just from here I don't know how to approach the problem. I understand that I have to add the points to get the total field, but it seems like I will get the same results for the 4 points since I am using
B = (μ0I)/(2r)
I'm thinking maybe the angle of the point crossing the circle from the interesection will affect my result for each individual points, but if it's the case, I wouldn't be sure how to take it into account
Ah yes! there's another little trap in the question.
The field has the same magnitude that's true (r is the same) - but has it the same direction?
ugh I was afraid it was going there, I could never understand how to figure the direction of the magnetic field
I know I have to use the right hand rule, but my question is two-fold
1) How do I know whether the current in the wire goes towards the extremity, or away from the extremity? Is it simply a convention?
2) I just don't know how to analyze the right hand rule, I know the way my fingers curl is the way of the magnetic field, but this becomes too abstract. Do you have sort of a rule of thumb to help me in deciding the direction?
Oh, I agree with you on the right-hand rule - it's cr@p!
I never use it.
It's very simple - the concept is based on a screw-motion. If you turn a screw clockwise it moves forward. Anti-clockwise is backwards.
Similarly, (given no friction) if you push a screw forward it turns clockwise and vice-versa.
The screw is going down the direction of current. It rotates in the direction of the magnetic field. How easy is that?
I never use it.
Heh actually that's quite easy to use, more straight-forward than the hand, but my problem remains the same. Once I find the direction of the magnetic field I just don't know how to apply it - and this isn't only for this problem, it's for any problem in general.
I'm sorry, I know I'm very slow understanding this problem, but the whole concept is very alien to me unfortunately. At least I got the drawing part, but it's the whole concept of figuring out the direction that has me completely lost
It takes a while to get used to it but it's quite easy really.
You can figure out the direction of the field from the corkscrew rule I just gave you. The magnitude is simply the formula H = etc.
In this problem it's been made a bit easier because the wires are in the plane of the paper and that means the field (in the plane) can only be straight up towards you or down through the table.
All you have to figure out (for each wire) is where the field is coming up and where it's going down.
If the field from both wires is in the same direction, they add. If not - they oppose.
Ok I'm starting to figure it out piece by piece. My question is, to find the magnetic field direction, I need to know the direction of the current. Maybe it's because my brain is fried right now, but how do I determine the direction of the current in a wire when I have no positive or negative pole?
Or... Would I be wrong in saying that both points to the right of the intersection go inside the paper, while both points to the left of the intersection go towards me? If that's the case, wouldn't the answer be 0?
It's stated in the question: the angle between current directions is 30°. (not 150° notice)
You'll find that specifies absolutely the relationship of the current to the two points of interest (the diagram could be mirror imaged - but that makes no difference because of symmetry)
Ok so basically one current will point to the right, and one to the left?
Is that a guess?
Two roads cross at an angle. Traffic on one road is traveling at 30° to the traffic on the other. That's sort of like a slip road. They are traveling almost in the same direction.
AJ Bentley said:
Is that a guess?
Ok you're right, they are both traveling in the same direction, I re-read correctly the part about the 30 degree angle, it gives us the direction of the current relative one wire to another
So if both currents flow in the same direction (let's just say left to right), I push a screw, it goes clock-wise, so inside the paper. But since both wire have the same current direction, wouldn't all four points be in the same direction?
So my magnetic field would be 4x each individual points
That's the trap.
AJ Bentley said:
That's the trap.
I just can't picture it otherwise. The way I see it:
The problem mentions "the angle between current directions is 30°", so this means both wire's current will flow in the same direction. Let's say it flows left to right, on both wire, whether I use the screw rule or the right-hand rule, it gives me the same result. The magnetic field is clock-wise, thus it goes inside the paper.
I think there's a key aspect of the problem that I'm not grasping, because I can't analyze it further than that. The only one aspect that I see I could use is the angle when determining B for each point, but even using the angles, the end result, in my eye, is the same. All four points the magnetic field goes in the same direction
At least its a start, you forced me to think all the way to that part and now I understand the direction of the magnetic field (how to determine it), maybe it's how to apply the direction once I know it that is different?
Ah, no, the field circles around the wire remember? That means it goes down into the paper below the wire (the bottom of the page in the drawing) but above the wire it comes out (top of the page).
If you shade in the paper on one side of the wire where the field is 'up' in two different colours for each wire, you'll see something interesting.
Wait, if I'm following you correctly, does that mean that the only point coming out of the paper is the one on the top-right quadrant, while all three other points, the magnetic field is going inside the paper?
So basically I have 1x towards me, and 3x towards paper, would that be it?
Man I feel like you must be banging your head on a wall with all the exchanges we've been going through! Thanks a lot for guiding me through this btw, much appreciated!
You're getting it - not quite.
Get yourself a small piece of tracing paper. Draw a line (the wire) across it. Mark an arrow to show current direction left-to-right.
Above the wire the field is 'up'. Shade that side of the paper completely.
Now get another piece and do exactly the same. Place the two pieces on top of each other and tilt them so the lines cross at 30 degrees. You will see 4 distinct areas.
Don't worry - this is a very elegant question with a lot of physics packed into a tiny space. I'm enjoying showing it to you.
Is that what you meant by 4 areas? Very crudely done I know (never mind the random black line on the top area I don't know why my color changed like that)
#1 and #3: Mag field goes towards me from the bottom wire, but towards paper from top wire, they cancel out
#2: Mag field goes towards me from both wire
#4: Mag field goes towards paper from both wire
But if I look at it this way, it comes down to 0 again, so that can't be right either
That's exactly right.
At points exactly equidistant from the wires the two fields are the same. But in one place they exactly cancel and at the other they exactly double.
There's a thin line of exactly zero magnetic field in the narrow angle between the wires.
That's what the question was all about. Nice eh? very elegant.
Awesome, thank you so much!
It was a very tricky question, I guess it didn't help that I didn't understand the direction of the magnetic field. The good news is, I'm starting to get the concept quite well after working on this problem!
Thanks again!
Don't mention it ! Bye!
  • · Replies 21 ·
