Linear Transformation and Determinant
The discussion revolves around a linear transformation L defined from R(mxm) to R(nxn) and the relationship between the equality of L(A) and L(B) and the determinants of matrices A and B. Participants are tasked with proving or disproving whether det(A) equals det(B) under the condition that L(A) equals L(B).
  • Exploratory, Assumption checking
  • One participant attempts to prove the statement by considering the cases of the matrix representation C being nonsingular or singular. They express uncertainty about how to proceed when C is singular.
  • Another participant questions whether a counter-example would suffice to disprove the statement, suggesting specific transformations that could demonstrate differing determinants despite equal images under L.
The discussion is ongoing, with participants exploring different perspectives on the problem. Some guidance has been offered regarding the sufficiency of counter-examples, and there is a recognition of the complexity introduced by the singular case of the transformation.
Participants note that the linear transformation L could potentially map all matrices to the zero matrix, raising questions about the implications for determinants in such cases. There is also a mention of the need to consider the nature of L when determining the validity of the original proposition.
schaefera
Define L: R(mxm) to R(nxn). If L(A)=L(B), prove or disprove that det(A)=det(B).
I think I can prove that this is true.
L(A)=L(B) means that L(A)-L(B)=L(A-B)=0.
Now let C be the matrix representation of L. We have two possibilities:
1) C is nonsingular. If C is nonsingular, then C(A-B)=0, so A-B=0. Then det(A)-det(B)=0 and det(A)=det(B).
2) C is singular. Now I have an issue-- I don't know what to do!
Am I on the right path? Should I be disproving this?
I'd say if you don't aren't told L is nonsingular then you should try and disprove your proposition. Case 2) is definitely a problem!
An obvious point is that if L is linear transformation the maps every matrix to the 0 matrix, then L(A)= L(B) for all matrices A and B.
Does one counter-example suffice, then? Would the transformation sending everything to the 0 matrix be one?
If not, it should be simple enough to construct. Perhaps something like:
L(a,b,c,d)=(a+b,c,d,0) where that is a 2x2 matrix I wrote out in one line, then for (0,1,1,1) and (1,0,1,1) have the same image but different determinants.
Thanks!
Thanks!
L(X)=0 certainly works and that's enough. If you'd rather have a less trivial example, yours works too. But one example suffices.
  • · Replies 25 ·
  • · Replies 17 ·
