Are rays from opposite sides of a hot spot of CMB parallel or not?
The discussion revolves around the nature of light rays from hot spots of the cosmic microwave background (CMB) radiation and their implications for understanding the curvature of the universe. Participants explore whether these rays can be considered parallel and how this relates to the curvature of space in different cosmological models.
  • One participant questions whether the assumption of parallel rays is necessary for determining the curvature of the universe based on the angular size of CMB hot spots.
  • Another participant argues that the rays are not parallel in any scenario, comparing the situation to reflections in mirrors to illustrate how curvature affects perception.
  • A participant challenges the idea that rays from distant objects are parallel, suggesting that rays from different positions in the CMB are not parallel due to their origins.
  • It is noted that rays from a distant object can be approximately parallel, but this approximation breaks down when considering different points in the CMB map.
  • One participant suggests that the entire space between the hot spot and the observer can be conceptualized as a lens, which may affect how rays converge.
Participants express differing views on whether the rays from CMB hot spots can be considered parallel. There is no consensus on the implications of this for understanding the curvature of the universe.
The discussion highlights the complexity of interpreting light behavior in cosmological contexts, including the assumptions about parallelism and the effects of curvature on light propagation.
alkmini
hello
I have a question:
i am trying to understand how we find out that the curvature of the universe is zero using the angular size of the hot spots of the d microwave background radiation.
http://scienceblogs.com/startswithabang/2012/07/18/how-big-is-the-entire-universe/
there is a picture in this blog showing the light rays from the opposite sides of the hot spots.
My question is: doesn't the proof that the curvature is zero require that the rays are parallel to each other? If they are parallel in a positively curved universe they converge. But in a flat one they should remain parallel and in a negatively curved they should diverge. Then, in the last two cases, how do they meet in the eye?
Space news on Phys.org
Alkmini, The rays are not parallel in any of the examples.
Imagine being in a fairground hall of mirrors and looking at yourself. If you see yourself tall you know that the mirror is convex, if you see yourself small you know the mirror is concave, if you see yourself normal then you know that the mirror is straight. The blog is adopting the same approach (except it is a CMB hotspot that is being looked at and it is space that is curved instead of a mirror, and space is open / closed instead of concave / convex).
I hope that this helps.
Regards,
Noel.
thank you so much Noel
I understand the similarity with the mirrors
but isn't it true that rays coming from a distant object are parallel?
do you can consider the ENTIRE space between the spot and the eye as a mirror?
Rays from from the sources were sent out in all directions, just as our sun sends out rays in all directions. The two rays in question are the ones that happen to reach us, and are not parallel since they come from different positions, for the same reason that two sides of a nondegenerate triangle are necessarily not parallel.
Rays from a distant object are only approximately parallel if the size of the distant object is negligible compared to the distance to the object. As long as you are looking at pairs of different points in the CMB map this is no longer the case.
Alkmini,
The rays are a very close approximation to parallel ...but not quite and because of the huge distances, the very small deviation from parallel allows them to converge. As a result the measurements need to be very accurate, which is why it take science the effort and time that it does
In relation to space, it is better to consider the entire space between the spot and the eye as a lens (but that lens equates to a mirror in my simple example) - but it is the entire space.
Regards,
Noel.
thank you both Noel and Torquil for your explanations. they helped
  • · Replies 29 ·
  • · Replies 230 ·
22K
  • · Replies 21 ·
  • · Replies 62 ·
13K
