In a series circuit with 3 bulbs, does the voltage decrease?
In a series circuit with three identical bulbs, the voltage across each bulb does not decrease, and the brightness remains equal. The current is consistent throughout the circuit, and since each bulb has the same resistance, the power consumed (calculated as EI, where E is voltage and I is current) is identical for each bulb. Therefore, if the bulbs are identical, they will all exhibit the same brightness.
  • Understanding of series circuits
  • Knowledge of Ohm's Law
  • Familiarity with electrical power calculations
  • Basic concepts of resistance in electrical components
  • Study Ohm's Law in detail
  • Explore the concept of electrical power in circuits
  • Learn about the effects of resistance on current flow
  • Investigate series vs. parallel circuit configurations
Students of physics, electrical engineers, and anyone interested in understanding the behavior of electrical circuits.
DeltaOne
In a series circuit with 3 bulbs, does the voltage across each bulb decrease? I know the current is the same at all points in the circuit. My book says that the brightness of the bulbs are all equal. Is this true?
My idea is that the brightness will not be the same because of the resistance of each bulb. I'm not sure if I am correct.
Thanks in advance.
If the bulbs are identical, they will all have the same brightness.
The brightness is determined by the power consumed by the bulb. The power consumed by each bulb is EI where E is the voltage measured across the terminals of each bulb and I is the current (I being the same for each bulb). Since E = IR and they all have the same resistance, EI is the same for each bulb.
AM
