Optics - What is the magnification of this image
The discussion revolves around the use of a concave spherical mirror to project an image of a real object onto a sheet of paper. The focal length of the mirror is given as 8.0 cm, and the original poster seeks to determine the placement of the paper such that the image is twice as far from the mirror as the object, as well as the magnification of the image.
  • Participants discuss the relationship between image distance, object distance, and focal length, with some suggesting to set the image distance as twice the object distance. Questions about the definition of magnification and how to find the radius of curvature are also raised.
Some participants have provided guidance on using the magnification equation and the mirror equation to approach the problem. There are multiple interpretations of how to set up the equations, and while some calculations have been shared, there is no explicit consensus on the final approach or solution.
The original poster expresses uncertainty about the necessary information to include and seeks clarification on the concepts involved, indicating a potential lack of foundational understanding in optics.
FAIRMADIEN787
A concave spherical mirror can be used to project an image onto a sheet of paper, allowing the magnified image of an illuminated real object to be accurately traced. If you have a concave mirror with a focal length of 8.0 cm, where would you place a sheet of paper so that the image projected onto it is twice as far from the mirror as the object is?
cm
What would the magnification of the image be?
The image is real and inverted.
Hi,
This is my first time using this website. I am not sure what exactly I need to include, but I do know the equations for magnification. I do not understand how to find the image they are looking for nor the magnification. Also I was wondering if someone could tell me how to find the radius of curvature.
Thank you
To start with use you image/object/focal length relationship, set i = 2o, then solve for o.
What is your definition of magnification?
for reaching out! To find the image and magnification in this scenario, we can use the equation: M = -v/u, where M is the magnification, v is the image distance, and u is the object distance. In this case, the object distance is equal to the focal length, so u = 8.0 cm. We want the image to be twice as far from the mirror as the object, so v = 2u = 16 cm. Therefore, the magnification would be M = -16/8 = -2. This means that the image is inverted and twice the size of the object.
To find the radius of curvature, we can use the formula: R = 2f, where R is the radius of curvature and f is the focal length. In this case, the focal length is 8.0 cm, so the radius of curvature would be 2(8.0 cm) = 16 cm. I hope this helps! Let me know if you have any other questions.
for reaching out! To answer your question, we can use the magnification equation: M = -di/do, where M is the magnification, di is the image distance, and do is the object distance. In this case, we know that the image distance is twice the object distance, so we can set up the equation as: M = -2do/do. Simplifying this, we get M = -2. This means that the image will be twice the size of the object and will be inverted.
To find the radius of curvature, we can use the mirror equation: 1/do + 1/di = 1/f, where f is the focal length. We know that the focal length is 8.0 cm, so we can plug that in and solve for di. This will give us the image distance, which we can then use to find the radius of curvature using the formula: R = 2f.
  • · Replies 16 ·
10K
