Magnetic field seen by electron in thomas precession
The discussion revolves around the magnetic field experienced by an electron during Thomas precession and its relationship to Larmor's theorem. Participants explore the implications of rotating frames on magnetic fields, particularly in the context of angular momentum and motion equations in both rotating and non-rotating frames.
  • Some participants assert that according to Larmor's theorem, a rotating frame at the Larmor frequency perceives the magnetic field as nonexistent.
  • Others argue that while the electric and magnetic fields change under a velocity boost, they remain unaffected by rotation, leading to a balance of forces in the rotating frame.
  • A participant expresses confusion regarding the absence of a fictitious magnetic field in the equations of motion for Thomas precession, despite acknowledging that the actual magnetic field is unchanged.
  • Another participant clarifies that the equations of motion for both Larmor and Thomas precession can be reconciled, suggesting that the apparent differences arise from how the precession frequencies are represented.
  • Concerns are raised about the treatment of the magnetic field in the context of Thomas precession compared to other scenarios, such as nuclear magnetic resonance, where the static magnetic field does not appear in the equations of motion.
Participants express differing views on the treatment of magnetic fields in rotating frames, particularly regarding the presence or absence of fictitious fields and how they relate to angular momentum equations. The discussion remains unresolved with multiple competing perspectives.
There are limitations related to the assumptions made about the magnetic fields in rotating frames and the definitions of the various terms used in the equations of motion. The discussion does not resolve these complexities.
rays
According to Larmor's theorem, the magnetic field seen by a rotating frame is changed. In a frame that rotates at the Larmor frequency, the magnetic field appears nonexistent.
In the treatment of thomas precession, the magnetic field in the instantaneous resting frame (which is rotating to an observer in the laboratory frame) is as if the frame is not rotating. Why?
This is a misunderstanding. The E and B fields change under a velocity boost, but are unaffected by a rotation. A rotating frame causes a Coriolis force, and at the Larmor frequency the Coriolis force is just sufficient to balance the (unchanged) B field.
Bill_K,
Thank you! I understand that the actual B field is not changed during Larmor precession.
However, the equaiton of motion in the rotating frame should read
dL(angular momentum)/dt = gamma*L x (B-B') while B' is the fictitious magnetic field.
In Thomas precession, one writes
dL/dt (lab frame) = dL/dt (rotating frame) + omega X L
and
dL/dt (rotating frame) = gamma*L x (B - v X E/c)
The fictitious B field is missing in (B-vXE/c). Still don't understand why.
rays, There's nothing mysterious going on. In both cases, (dL/dt)rot = (dL/dt)nonrot - ω x L, where ω is the Larmor precession frequency in one case and the Thomas precession frequency in the other. The only reason they look different is because in the Larmor case they rewrite ω as a fictitious B field, and in the Thomas case they leave it as ω.
Thanks again.
In the rotating frame of thomas precession, the B field from the non rotating frame in its entirety is used to describe the motion in the rotating frame.
This seems in contradiction to the treatment of other scenarios. For example, in nuclear magnetic resonance, when one decribes the motion of nuclear spins in the Larmor rotating frame the static B field does not enter into the equation of motion.
Souldn't one use a B field in the rotating frame of the thomas precession that is different from the actual B field (in non rotating frame)? If one does that, then
dL/dt(rot) = magnetic moment X (B-a*omeag)
dL/dt(nonrot) = dL/dt(rot) + omeag X L = magnetic moment X B
The correction term from a*omega disapears from the energy calculation which is performed in the nonrotating frame.
rays
  • · Replies 33 ·
  • · Replies 28 ·
