GR: Black Hole - Electrical Charge
The discussion centers on the interaction between electric charges and black holes, specifically addressing whether acceleration or gravity influences the force of electric charges. It highlights that as a black hole forms, a 'Cosmic Wind' expels less dense negative ions while denser positive ions are attracted, potentially leading to a positive charge accumulation in the black hole. The conversation references the "no-hair" theorem, stating that charge, energy, and angular momentum are conserved properties in black holes, and emphasizes that while acceleration can affect the field of a moving charge, it does not alter the magnitude of charge itself.
  • Understanding of black hole formation and properties
  • Familiarity with electric charge and its conservation laws
  • Knowledge of the "no-hair" theorem in black hole physics
  • Basic principles of gravitational effects on charged particles
  • Research the implications of the "no-hair" theorem on black hole physics
  • Explore the effects of Cosmic Winds on matter surrounding black holes
  • Investigate the relationship between electric charge and gravitational fields
  • Study experimental setups for measuring electric charge variations in different gravitational environments
Physicists, astrophysicists, and students interested in the interplay between electromagnetism and general relativity, particularly those studying black hole dynamics and charge conservation.
RandallB
A GR? Does Acceleration or Gravity affect the force of electric charges?
Example: Material is forming a Black Hole
Heat is creating a ‘Cosmic Wind’ – that is blowing less dense matter away while denser matter is being favored for forming and enlarging the Black Hole.
And material is made up of positive Ions of very Dense make up, but Negative Ions are not dense, So their “fluffiness” is preventing them from going in.
Will the Black Hole acquire a “Positive” charge; Can the force of that charge be able to reach out of the black hole, start to push away more + ions, and overcome the ‘wind’ on the - ions: Thus keep it in a more neutral charge, avoiding an increasing charge.?
Experiment is our solar system:
A Large heavy plate is supported by insulated struts capable of measuring the weight of the plate without significant displacement of distance over another large plate.
On Earth the weight is 150 lbs when a measured charge is applied that lowers the weight to 140 lbs. Repulsive charge is supporting 10 lbs of the weight.
Taking the experiment to Pluto, our Moon, and Jupiter will give weights very close to 10 lbs, 25lbs, and 380lbs. When the same charge is applied should we expect the same 10 lbs change. Or should gravity have some small affect on power of charge to repel?
RB
Charge is one of the few properties that isn't destroyed by black holes (the other two are energy and angular momentum). This is a statement of the so called "no-hair" theorem.
In any situation, charge is conserved. It is one thing for acceleration to affect the field due to a moving charge (yes) and another thing for the acceleration to affect the magnitude of charge (no, charge is strictly conserved)
Thanks - I guess at least some information can get out of a Black Hole.
RB
  • · Replies 62 ·
10K
  • · Replies 19 ·
  • · Replies 35 ·
  • · Replies 17 ·
