Why Does the Antiderivative Represent the Area Under a Curve?
  • Context: Undergrad
  • Thread starter Thread starter Psyguy22
    Integration Works
The antiderivative of a continuous function represents the area under its curve, as established by the Fundamental Theorem of Calculus. For a continuous function f(x) that is non-negative over the interval [a, x], the area F(x) from a to x can be expressed as the limit of the average value of f over increasingly smaller intervals. This relationship is defined mathematically as F'(x) = f(x), confirming that the area under the curve is indeed calculated using the antiderivative.
  • Understanding of the Fundamental Theorem of Calculus
  • Knowledge of limits and continuity in calculus
  • Familiarity with the concept of antiderivatives
  • Basic properties of area in geometry
  • Study the Fundamental Theorem of Calculus in detail
  • Explore the concept of limits and their applications in calculus
  • Learn about the properties of continuous functions
  • Investigate various methods for calculating areas under curves
Students of calculus, mathematics educators, and anyone interested in understanding the relationship between derivatives and areas under curves.
Psyguy22
Basically my question is, how do we know that the antiderivitave of a function represents the area under that curve?
If you look graphically, you can see that the area of f(x)=x from 0 to 1 is 1/2 which agrees with (x^2)/2 but why?
We know that because we have proven it. The statement is exactly the fundamental theorem of calculus. The proof of that theorem tells us why we can calculate areas with the inverse of derivatives.
The fact is certainly not trivial and is in fact quite a deep theorem.
Let y= f(x) be continuous function such that [itex]f(x)\ge 0[/itex] for all [itex]a\le x[/itex]. Define F(x) to be the area under the graph from a to x. Then F(x+[itex]\Delta[/itex]x) is the area under the graph from a to x+ [itex]\Delta[/itex]x. F(x+ [itex]\Delta[/itex]x)- F(x) is the area under the graph from x to x+ [itex]\Delta[/itex]x. Because f is continuous (this is the "deep" part!), there exist some x', [itex]x\le x'\le x+ \Delta x[/itex], such that [itex]f(x')\Delta x[/itex] is equal to that area. That is, [itex]F(x+ \Delta x)- F(x)= f(x')\Delta x[/itex] so that
[tex]\frac{F(x+ \Delta x)- F(x)}{\Delta x}= f(x')[/tex]
Now, x' is always between x and x+ [itex]\Delta[/itex] x so if we take the limit as [itex]\Delta[/itex]x goes to 0, f(x') goes to f(x). That is:
[tex]\lim_{\Delta x\to 0}\frac{F(x+ \Delta x)- F(x)}{\Delta x}=\frac{dF}{dx}= f(x)[/tex]
That is, the area really is given by an anti-derivative. The interesting thing is that to do this- and so be able to calculate the are of some very complicated sets- we don't have to give a very detailed definition of "area". All that is needed about area is
1) The area of a set is a non-negative number
2) If sets A and B are disjoint (except possibe on their boundaries) the area of A U B is the area of A plus the area of B
3) The area of a rectangle is "height times width".
  • · Replies 20 ·
