Calculate Magnetic Field Between Two Wires: Help Needed
  • Thread starter Thread starter waywardtigerlily
    Current Wires
The discussion focuses on calculating the net magnetic field between two parallel wires carrying currents of 5.12A in opposite directions, separated by 9.33 cm. The correct formula for the magnetic field due to a long straight wire is B = (μ₀I)/(2πr). For the midpoint calculation, the net magnetic field is derived from the contributions of both wires, leading to B_mid = (2μ₀I)/(πd₀). The calculations for points p1 and p2 require careful attention to the distances and directions of the currents, ensuring proper subtraction of fields due to opposite current directions.
  • Understanding of Ampère's Law and magnetic fields
  • Familiarity with the formula B = (μ₀I)/(2πr)
  • Knowledge of vector subtraction in magnetic field calculations
  • Basic skills in unit conversion (cm to m)
  • Study the derivation of Ampère's Law and its applications
  • Learn about the Biot-Savart Law for magnetic field calculations
  • Explore the effects of current direction on magnetic field interactions
  • Practice problems involving multiple current-carrying wires
Physics students, electrical engineers, and anyone interested in electromagnetism and magnetic field calculations.
waywardtigerlily
Ok, I have been working on this problem for about 2 hours now, and I still can't get the right answer..could someome help me?
two wires carry currents of I=5.12A in opposite directions and are separated by a distance of d0=9.33cm. (the wire on the left has I going up and the one on the right is going down) Calculate the net magnetic field at a point midway between the wires. Use the direction out of the page as the positive direction and into the page as the negative direction in your answer.
B. Calculate the net magnetic field at point p1- that is 9.32 cm to the right of the wire on the right.
C. calculate the net magnetic field at point p2- that is 19.3 cm to the left of the wire on the left.
To calculate B. I am using:
BR=uoI
2pi (p1/2)
BR= (4pi x 10^-7)(5.12)
(2Pi)(.0466)
= 2.19742 x 10^-5 T
BL=uoI
2pi(p1+do)
BL= (4pi x 10^-7)(5.12)
2Pi(.1865)
Bnet= BR-BL
= 1.65 x 10 ^-5 T
Can anyone see what I am doing wrong? I assume for C you would use the same procedure and for the main question you would just use Bnet= B1+B2
Thanks!
BR=uoI2pi (p1/2)
You did not write the division sign. Looks like it's a typo.
Any way BR = UoI / 2pi (p1). where p1 = 9.31 cm. Rest of your calculations seems to be ok.
I am not sure what you are using for part a. You have to be careful with the directions r. Use:
(1)[tex]B = \frac{\mu_0I}{2\pi r}[/tex]
For a., r1 = d0/2 and r2=-d0/2, so:
[tex]B_{mid} = \frac{\mu_0}{\pi d_0}I + \frac{\mu_0}{\pi (-d_0)}(-I) = \frac{2\mu_0}{\pi d_0}I[/tex]
For part b., r1 = d0 and r2 = 2d0 (ie. both positive) . When you work out the fields, you have to subtract them due to the different directions of the currents
For part c., r1 = -(d0 + 10) and r2 = -(2d0 + 10) (ie. both negative) . When you work out the fields, again you have to subtract them due to the different directions of the currents.
AM
18K
