Magnetic field outside solenoid
The magnetic field outside a finite solenoid can be calculated using the Biot–Savart law. For a solenoid with parameters L = 25 cm, R = 10 cm, N = 1000, and I = 1 A, the field at a distance of 10 cm from one end requires integration of the contributions from each segment of the solenoid. This approach applies to both points directly on the z-axis and those not aligned with it, ensuring accurate results for finite-length solenoids.
  • Understanding of the Biot–Savart law
  • Familiarity with magnetic field concepts
  • Knowledge of calculus for integration
  • Basic principles of electromagnetism
  • Study the application of the Biot–Savart law in various configurations
  • Learn about magnetic field calculations for finite solenoids
  • Explore numerical methods for solving integrals in electromagnetism
  • Investigate the effects of solenoid parameters on magnetic field strength
Physics students, electrical engineers, and anyone interested in advanced electromagnetism and magnetic field calculations.
anthell
Instead of the usual
B = μ0NI for field inside solenoid...
how should i go about finding the field let say... 10cm away from one end of the solenoid
1. directly at the z-axis
2. not directly at the z-axis
this is assuming the solenoid has finite length, finite number of turns ,finite radius
(ex. L = 25cm , R = 10cm, N = 1000, I = 1A)
Please help me out hehe thx
You can use the Biot–Savart law or some equations derived from that law.
