(THERMO) - Adiabatic Expansion - known P1, P2, and T1
The discussion focuses on calculating the maximum temperature of air in a bicycle pump during adiabatic expansion, where initial pressure P1 is 10^5 Pa, final pressure P2 is 30^5 Pa, and initial temperature T1 is 293 K. The user attempted to apply the first law of thermodynamics and ideal gas laws but encountered errors in their calculations, particularly in the use of the volume ratio and the exponent in the temperature equation. The correct approach involves using the ideal gas law to relate temperature and pressure directly, rather than relying on volume, which is unspecified.
  • Understanding of the first law of thermodynamics
  • Knowledge of ideal gas laws
  • Familiarity with adiabatic processes
  • Basic calculus for integration
  • Study the derivation of the ideal gas law and its applications
  • Learn about adiabatic processes in thermodynamics
  • Explore the relationship between pressure, volume, and temperature in ideal gases
  • Review the first law of thermodynamics and its implications for internal energy changes
Students and professionals in thermodynamics, mechanical engineers, and anyone involved in the study of gas behavior under varying pressure and temperature conditions.
Zomboy
Question:
in a bicycle pump the preasure increases from [p1 = 10^5] to [p2 = 30^5]. If the process is adiabatic ant the air starts at [T1 = 293 K], find the maximum temperature of the air in the pump. (Assuming air can be treated as an ideal gas)
Attempt:
So using the 1st Law and given that its adiabatic (no heat input/output) I've written:
U = W
(C_v)dT = PdV
(C_v)dT = (nR) (1/v) dV
then integrated and re-arranged to obtain:
T2 / T1 = (V2/V1)^(nR/c)
then substituted in { C_v = nR5/2 } because its an adiabatic process, and { T2 P1 / P2 T1 } for V2/V1 using the equation for an ideal gas...
But then when I re-arranged to find T2 I found it to be 33K which is wrong of course...
Is this sort of the way to do it? Its just I can't think of another way seeing as it doesn't specify the initial volume of the tyre...
This equation does not look right. If the volume increases (expansion) the temperature should decrease.
And there is no "n" in the exponent.
The change in internal energy is nCvΔT.
Anyway, what is the point in finding a T,V relationship when you know the pressures but not the volumes?
Use the gas law to substitute V in the first law and integrate to find a relationship between T and p. It's more straightforward.
